PlotStyle Location
PlotStyle Location
PlotStyle Location
Hi Guys,
there is a way for find the plotstyles and plotter configuration location via C or VB.Net?
I have some user that have a personalized location and I am writinng a procedure for create Batch Etransmit whit the lib.
Stefano
Norman_Yuan
You would need to use COM object AcadApplication:
dynamic comAcad=Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
string[] stylePaths=comAcad.Preferences.Files.PrinterStyleSheetPath.Split(';');
Then for each style sheet path/folder, you would loop through all files in the folder for the "*.ctb" file of your target.
Norman Yuan
Drive CAD With Code
