CREATE A HORIZONTAL DIMENSIONAL CONSTRAINT
I seem to at a loss here. I find all kinds of info on creating aligned dimensional constraints but I can't find anything on creating horizontal or vertical dimensional constraints. Can someone please point me in the right direction???
deepak.a.s.nadig
Please refer the samples in below post under the topic "Creating Geometric and Dimensional Constraints Using the AutoCAD® .NET API"
http://through-the-interface.typepad.com/through_the_interface/2010/12/some-content-from-au-2010.htm...
A VB.NET sample code taken from the above post to create horizontal constraint :
Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Namespace Parametric_API_Demo_VB
    Public Class MyCommands
        <CommandMethod("testhorizontalConstraints")> Public Sub testhorizontalConstraints()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim peo As PromptEntityOptions = New PromptEntityOptions(vbLf & "Select a curve")
            peo.SetRejectMessage("Please select a curve")
            peo.AddAllowedClass(GetType(Curve), False)
            Dim per As PromptEntityResult = ed.GetEntity(peo)
            If per.Status <> PromptStatus.OK Then Return
            Dim tr As Transaction = db.TransactionManager.StartTransaction()
            Using tr
                Dim curve As Curve = TryCast(tr.GetObject(per.ObjectId, OpenMode.ForRead), Curve)
                If curve IsNot Nothing Then
                    SetHorizontalConstraint(curve, tr)
                tr.Commit()
            End Using
        End Sub
        Public Sub SetHorizontalConstraint(ByVal curve As Curve, ByVal trans As Transaction)
            Using trans2 As Transaction = trans.TransactionManager.StartTransaction()
                Dim SubEntEdgePath As FullSubentityPath 'logical path to the edge (one edge object pretty simple)
                CreateSubEntityPath(curve, SubEntEdgePath, trans2)
                'Our constrained geometry will be the edge of the line
                Dim consGrpId As ObjectId = GetConstraintGroup(True, trans2)
                Dim consGeom As ConstrainedGeometry = Nothing
                Using constGrp As Assoc2dConstraintGroup = DirectCast(trans2.GetObject(consGrpId, OpenMode.ForWrite, False), Assoc2dConstraintGroup)
                    'Add the constrained geometry to which the geometrical constraint will be applied
                    Try
                        consGeom = AddConstrainedGeometry(constGrp, SubEntEdgePath)
                    Catch ex As Autodesk.AutoCAD.Runtime.Exception
                        'aready there move on
                    End Try
                    Dim paths As FullSubentityPath() = New FullSubentityPath(0) {SubEntEdgePath}
                    'Now add the geometrical constraint
                    Dim newConstraint As GeometricalConstraint = Nothing
                    newConstraint = constGrp.AddGeometricalConstraint(GeometricalConstraint.ConstraintType.Horizontal, paths)
                    Dim constraintArray As New List(Of GeometricalConstraint)()
                    constraintArray.Add(newConstraint)
                End Using
                trans2.Commit()
            End Using
        End Sub
        Private Sub CreateSubEntityPath(ByVal curve As Curve, ByRef SubEntEdgePath As FullSubentityPath, ByVal trans As Transaction)
            Using entity As Entity = DirectCast(trans.GetObject(curve.ObjectId, OpenMode.ForRead, False), Entity)
                If entity Is Nothing Then
                    System.Windows.MessageBox.Show("Cannot Get entity")
                    Exit Sub
                'get the added language controls to work with sub entities (Protocal Extension)
                Dim subentityIdPE As AssocPersSubentityIdPE = GetProtocalExtension(entity)
                Dim edgeSubentityIds As SubentityId() = Nothing
                'break the first curve down into its sub entities
                edgeSubentityIds = subentityIdPE.GetAllSubentities(entity, SubentityType.Edge)
                'create a logical path from the entity to the desired point
                SubEntEdgePath = New FullSubentityPath(New ObjectId(0) {curve.ObjectId}, edgeSubentityIds(0))
            End Using
        End Sub
        Public Function AddConstrainedGeometry(ByVal constGrp As Assoc2dConstraintGroup, ByVal SubEntPath As FullSubentityPath) As ConstrainedGeometry
            'check constrGroup for existing path
            Dim cgIndex As Integer = constGrp.ConstrainedGeometries.Length
            If cgIndex > 0 Then
                For index As Integer = 0 To cgIndex - 1
                    Dim cg As ConstrainedGeometry = constGrp.ConstrainedGeometries(index)
                    Dim fspIndex As Integer = cg.FullSubentityPaths.Length
                    If fspIndex > 0 Then
                        For jIndex As Integer = 0 To fspIndex - 1
                            Dim fsp As FullSubentityPath = cg.FullSubentityPaths(jIndex)
                            If fsp = SubEntPath Then
                                Return cg
                        Next
                Next
            consGeom = constGrp.AddConstrainedGeometry(SubEntPath)
            Return consGeom
        End Function
        Private Function GetConstraintGroup(ByVal createIfDoesNotExist As Boolean, ByVal trans As Transaction) As ObjectId
            ' Calculate the current plane on which new entities are added by the editor
            ' (A combination of UCS and ELEVATION sysvar).
            Dim ed As Autodesk.AutoCAD.EditorInput.Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
            Dim ucsMatrix As Matrix3d = ed.CurrentUserCoordinateSystem
            Dim origin As Point3d = ucsMatrix.CoordinateSystem3d.Origin
            Dim xAxis As Vector3d = ucsMatrix.CoordinateSystem3d.Xaxis
            Dim yAxis As Vector3d = ucsMatrix.CoordinateSystem3d.Yaxis
            Dim zAxis As Vector3d = ucsMatrix.CoordinateSystem3d.Zaxis
            origin = origin + CDbl(Application.GetSystemVariable("ELEVATION")) * zAxis
            Dim currentPlane As New Plane(origin, xAxis, yAxis)
            ' get the constraint group from block table record
            Dim idConstrGroup As ObjectId = ObjectId.Null
            Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
            Dim networkId As ObjectId = AssocNetwork.GetInstanceFromObject(SymbolUtilityServices.GetBlockModelSpaceId(db), createIfDoesNotExist, True, "")
            If networkId.IsNull Then
                System.Windows.MessageBox.Show("Network id is null")
                Return idConstrGroup
            ' Try to find the constraint group in the associative network
                Using network As AssocNetwork = DirectCast(trans2.GetObject(networkId, OpenMode.ForRead, False), AssocNetwork)
                    If network Is Nothing Then
                    ' Iterate all actions in network to find Assoc2dConstraintGroups
                    Dim actionsInNetwork As ObjectIdCollection = network.GetActions
                    For nCount As Integer = 0 To actionsInNetwork.Count - 1
                        Dim idAction As ObjectId = actionsInNetwork(nCount)
                        If idAction = ObjectId.Null Then
                            Continue For
                        ' Is this action a type of Assoc2dConstraintGroup?
                        If idAction.ObjectClass.IsDerivedFrom(RXObject.GetClass(GetType(Autodesk.AutoCAD.DatabaseServices.Assoc2dConstraintGroup))) Then
                            Using action As AssocAction = DirectCast(trans2.GetObject(idAction, OpenMode.ForRead, False), AssocAction)
                                If action Is Nothing Then
                                    Continue For
                                Dim constGrp As Assoc2dConstraintGroup = DirectCast(action, Assoc2dConstraintGroup)
                                ' Is this the Assoc2dConstraintGroup for our plane of interest?
                                If constGrp.WorkPlane.IsCoplanarTo(currentPlane) Then
                                    ' If it is then we've found an existing constraint group we can use.
                                    Return idAction
                            End Using
                    Next
                End Using
                ' If we get to here, a suitable contraint group doesn't exist, create a new one if that's what calling fn wanted.
                If idConstrGroup.IsNull AndAlso createIfDoesNotExist Then
                    Using network As AssocNetwork = DirectCast(trans2.GetObject(networkId, OpenMode.ForWrite, False), AssocNetwork)
                        ' Create  construction plane
                        Dim constraintPlane As New Plane(currentPlane)
                        ' If model extent is far far away from origin then we need to shift
                        '  construction plane origin within the model extent.
                        ' (Use Pextmin, PExtmax in paper space)
                        Dim extmin As Point3d = db.Extmin
                        Dim extmax As Point3d = db.Extmax
                        If extmin.GetAsVector().Length > 100000000.0 Then
                            Dim originL As Point3d = extmin + (extmax - extmin) / 2.0
                            Dim result As PointOnSurface = currentPlane.GetClosestPointTo(originL)
                            constraintPlane.[Set](result.GetPoint(), currentPlane.Normal)
                        ' Create the new constraint group and add it to the associative network.
                        Using constGrp As New Assoc2dConstraintGroup(constraintPlane)
                            idConstrGroup = db.AddDBObject(constGrp)
                        End Using
                        network.AddAction(idConstrGroup, True)
                    End Using
                trans2.Commit()
            End Using
        End Function
        Public Function GetProtocalExtension(ByVal ent As Entity) As AssocPersSubentityIdPE
            Dim peCls As RXClass = AssocPersSubentityIdPE.GetClass(GetType(AssocPersSubentityIdPE))
            Dim pSubentityIdPE As IntPtr = ent.QueryX(peCls)
            If pSubentityIdPE = IntPtr.Zero Then
                System.Windows.MessageBox.Show("cannot get pSubentityIdPE1")
                Return Nothing
            subentityIdPE = TryCast(AssocPersSubentityIdPE.Create(pSubentityIdPE, False), AssocPersSubentityIdPE)
            If subentityIdPE Is Nothing Then
                System.Windows.MessageBox.Show("cannot get subentityIdPE1")
                Return Nothing
            Return subentityIdPE
        End Function
    End Class
End Namespace
This code appears to be for creating a horizontal constraint. I want to create a horizontal dimensional constraint.
deepak.a.s.nadig
I have modified the command "TESTALIGNEDDIM" from the sample ( http://download.autodesk.com/media/adn/AutoCAD_Parametric_Drawing_DotNet_API.zip )  to create Horizontal Dimensional constraint.
For vertical alignment, you can use the vector in Y-direction as below
constGrp.AddDistanceConstraint(consStartPt, consEndPt, DistanceConstraint.DistanceDirectionType.FixedDirection, valDepId, dimDepId, New Vector3d(0, 1, 0), Nothing)
        'Add an horizontal dimensional constraint to a Line.
        <CommandMethod("TESTHORIZONTALDDIM")>
        Public Shared Sub testhorizontaledDimCommand()
            Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = db.TransactionManager
            Using myT As Transaction = tm.StartTransaction()
                ' Point entities
                Dim bt As BlockTable = DirectCast(myT.GetObject(db.BlockTableId, OpenMode.ForRead, False), BlockTable)
                Dim btr As BlockTableRecord = DirectCast(myT.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite, False), BlockTableRecord)
                Dim point3d1 As New Point3d(10, 10, 0)
                Dim point3d2 As New Point3d(20, 20, 0)
                Dim dimPt As New Point3d(36, 20, 0)
                Dim line1 As New Line(point3d1, point3d2)
                btr.AppendEntity(line1)
                myT.AddNewlyCreatedDBObject(line1, True)
                ' Horizontal Dimension entity
                Dim dimHorizontal As New RotatedDimension(0.0, point3d1, point3d2, dimPt, "ROTATED DIMENSION", db.Dimstyle)
                btr.AppendEntity(dimHorizontal)
                myT.AddNewlyCreatedDBObject(dimHorizontal, True)
                'To query the subentities of the line, we create and use a protocol extension (PE) provided by the associativity API
                Dim pSubentityIdPE As IntPtr = line1.QueryX(peCls)
                    System.Windows.MessageBox.Show("cannot get pSubentityIdPE")
                    Return
                    System.Windows.MessageBox.Show("cannot get subentityIdPE")
                    Return
                'Now we have the PE, we query the subentities
                'First we retrieve a list of all edges (a line has one edge)
                edgeSubentityIds = subentityIdPE.GetAllSubentities(line1, SubentityType.Edge)
                Dim startSID As SubentityId = SubentityId.Null, endSID As SubentityId = SubentityId.Null
                Dim other As SubentityId() = Nothing
                'Now we retrieve the vertices associated with that edge.
                subentityIdPE.GetEdgeVertexSubentities(line1, edgeSubentityIds(0), startSID, endSID, other)
                'The PE returns a SubEntId. We want a Full SubentityPath
                Dim subentPathEdge As New FullSubentityPath(New ObjectId(0) {line1.ObjectId}, edgeSubentityIds(0))
                Dim subentPath1 As New FullSubentityPath(New ObjectId(0) {line1.ObjectId}, startSID)
                Dim subentPath2 As New FullSubentityPath(New ObjectId(0) {line1.ObjectId}, endSID)
                'add dimconstraint to the entities
                'create value dependency
                Dim varId As ObjectId, valDepId As ObjectId
                varId = AddOrModifyVariable("Horizontal", "10.0")
                Using valDep As New AssocValueDependency()
                    valDepId = db.AddDBObject(valDep)
                    Dim compoundId As New CompoundObjectId(varId, db)
                    valDep.AttachToObject(compoundId)
                End Using
                'create dim dependency
                Dim dimDepId As ObjectId = ObjectId.Null
                Dim dimDepBodyId As ObjectId = ObjectId.Null
                AssocDimDependencyBody.CreateAndPostToDatabase(dimHorizontal.ObjectId, dimDepId, dimDepBodyId)
                Dim bPreviousValue As Boolean = AssocDimDependencyBodyBase.SetEraseDimensionIfDependencyIsErased(False)
                Dim consGrpId As ObjectId = GetConstraintGroup(True)
                Dim consGeom0 As ConstrainedGeometry = Nothing
                Dim consLine As ConstrainedLine = Nothing
                Using constGrp As Assoc2dConstraintGroup = DirectCast(myT.GetObject(consGrpId, OpenMode.ForWrite, False), Assoc2dConstraintGroup)
                    consGeom0 = constGrp.AddConstrainedGeometry(subentPathEdge)
                    'Sometimes you have to access implicit constrained geometry.
                    'In this case, we're constraining the lines by its endpoints, so we have to query the constrained line edge for its ConstrainedImplicitPoints.
                    'If we try to pass the line's end point subentity directly via a call to AddConstrainedGeometry, we'll get an error.
                    consLine = DirectCast(consGeom0, ConstrainedLine)
                    Dim consPts As ConstrainedImplicitPoint() = consLine.ConstrainedImplicitPoints
                    Dim consStartPt As ConstrainedGeometry = Nothing
                    Dim consEndPt As ConstrainedGeometry = Nothing
                    'We don't know which is start or end point, so we test. (And we could have a midpoint in there too).
                    For Each pt As ConstrainedImplicitPoint In consPts
                        If pt.PointType = ImplicitPointType.StartImplicit Then
                            consStartPt = pt
                        If pt.PointType = ImplicitPointType.EndImplicit Then
                            consEndPt = pt
                    Next
                    'If something went wrong ...
                    If (consStartPt Is Nothing) OrElse (consEndPt Is Nothing) Then
                        Return
                    'Now we add our constraint
                    constGrp.AddDistanceConstraint(consStartPt, consEndPt, DistanceConstraint.DistanceDirectionType.FixedDirection, valDepId, dimDepId, New Vector3d(1, 0, 0),
                     Nothing)
                    AssocDimDependencyBodyBase.SetEraseDimensionIfDependencyIsErased(bPreviousValue)
                End Using
                myT.Commit()
            End Using
        End Sub
        ' Helper function to return FullSubEntPath for subent of provided entity
        Private Shared Function GetFullSubentityPath(ByVal entity As Entity, ByVal subentityType As SubentityType) As FullSubentityPath
                System.Windows.MessageBox.Show("cannot get entity")
                Return New FullSubentityPath()
            Dim pSubentityIdPE As IntPtr = entity.QueryX(peCls)
            edgeSubentityIds = subentityIdPE.GetAllSubentities(entity, subentityType)
            Return New FullSubentityPath(New ObjectId(0) {entity.ObjectId}, edgeSubentityIds(0))
        End Function
        ' Helper function to retrieve (or create) constraint group
        Private Shared Function GetConstraintGroup(ByVal createIfDoesNotExist As Boolean) As ObjectId
                System.Windows.MessageBox.Show("network id is null")
                Using network As AssocNetwork = DirectCast(myT.GetObject(networkId, OpenMode.ForRead, False), AssocNetwork)
                            Continue For
                            Using action As AssocAction = DirectCast(myT.GetObject(idAction, OpenMode.ForRead, False), AssocAction)
                                    Continue For
                                    Return idAction
                            End Using
                    Next
                End Using
                    Using network As AssocNetwork = DirectCast(myT.GetObject(networkId, OpenMode.ForWrite, False), AssocNetwork)
                        End Using
                    End Using
                myT.Commit()
            End Using
        End Function
        ' Helper function to add a new variable to the associative network or modify expression of the existing one
        Private Shared Function AddOrModifyVariable(ByVal varName As String, ByVal varExpression As String) As ObjectId
            Dim varId As ObjectId = ObjectId.Null
            Using myT As Transaction = db.TransactionManager.StartTransaction()
                ' Open the AssocNetwork
                Dim networkId As ObjectId = AssocNetwork.GetInstanceFromObject(SymbolUtilityServices.GetBlockModelSpaceId(db), True, True, "")
                Dim network As AssocNetwork = DirectCast(myT.GetObject(networkId, OpenMode.ForWrite), AssocNetwork)
                Dim var As AssocVariable = Nothing
                ' Iterate through all actions in the network
                Dim actionIds As ObjectIdCollection = network.GetActions
                For Each actionId As ObjectId In network.GetActions
                    ' Is this action an AssocVariable?
                    If actionId.ObjectClass.IsDerivedFrom(RXObject.GetClass(GetType(Autodesk.AutoCAD.DatabaseServices.AssocVariable))) Then
                        ' If so, we check if it has the name we're looking for.
                        var = DirectCast(myT.GetObject(actionId, OpenMode.ForWrite), AssocVariable)
                        If var IsNot Nothing Then
                            ' If name matches, then we exit loop and set its expression
                            If var.Name = varName Then
                                Exit For
                            Else
                                var = Nothing
                Next
                ' If variable with correct name wasn't found, we create it.
                If var Is Nothing Then
                    var = New AssocVariable()
                    varId = network.Database.AddDBObject(var)
                    network.AddAction(varId, True)
                    myT.AddNewlyCreatedDBObject(var, True)
                    var.SetName(varName, True)
                ' Finally we set its expression to the new value.
                Dim errMsg As String = ""
                var.SetExpression(varExpression, "", True, True, errMsg, False)
                Dim rb As New ResultBuffer()
                errMsg = var.EvaluateExpression(rb)
                var.Value = rb
                myT.Commit()
            End Using
            Return varId
        End Function
        ' Helper function to handle exceptions being thrown if you try to add the same constrained geometry twice.
        ' You could work out what constrained geometry to add up front. That would be more efficient as no exceptions would be thrown,
        '  but isn't always possible (e.g. if running a command multiple times to constrain existing geometry in a drawing.
        ' (This helper function isn't used by any functions in this sample project).
        Private Shared Function AddConstrainedGeometry(ByVal constGrp As Assoc2dConstraintGroup, ByVal path As FullSubentityPath) As ConstrainedGeometry
            Try
                consGeom = constGrp.AddConstrainedGeometry(path)
                ' This error isn't really an an error
                If ex.ErrorStatus <> ErrorStatus.AlreadyInGroup Then
                    Throw ex
                ' If we get to here, then 'path' was already in the group so we can retrieve it.
                consGeom = constGrp.GetConstrainedGeometry(path, False)
            End Try
            Return consGeom
        End Function
    End Class
