Plot to plt file using a system printer
In our drawings we have a layout with a view port and tittle block.
Default printer set for that layout is "dwg to pdf.pc3" and paper is "ISO A3".
I had to plot this layout [extence] to a plt file for the use of our Production ERP.
We had to print to a specific windows printer with paper size A3.
We use to do it in VBA with the bellow code.
How to do it in .Net
Public Function BetsyPlot2() As Boolean
    Dim Plot As AcadPlot
    Dim alayout As AcadLayout
    Dim lowerLeft(0 To 1) As Double
    Dim upperRight(0 To 1) As Double
    Dim retval As Boolean
    retval = flase
    For Each alayout In ThisDrawing.layouts
        If alayout.Name = "Betsy" Then
            RedrawViewPort
            ThisDrawing.ActiveLayout = alayout
            ThisDrawing.SetVariable "ANNOALLVISIBLE", 1
            lowerLeft(0) = 0
            lowerLeft(1) = 0
            upperRight(0) = 400
            upperRight(1) = 275
            alayout.SetWindowToPlot lowerLeft, upperRight
            alayout.PlotType = acWindow
            'alayout.UseStandardScale = True
            alayout.StandardScale = acScaleToFit
            'ThisDrawing.ActiveLayout.PlotRotation = ac270degrees
            alayout.ShowPlotStyles = False    'if it is true this may cause the layout become black & wite
            ' MsgBox ("sss")
            Set Plot = alayout.Document.Plot
            ' Plot.DisplayPlotPreview acPartialPreview
            ThisDrawing.SetVariable "BACKGROUNDPLOT", 0
            Call CreateDirectory(Trim(Me.txtFileNo.Text), BasePath)
            retval = Plot.PlotToFile(BasePath & Me.txtFileNo.Text & "\" & Me.txtDwgNo.Text & ".plt", comboPlotPrinter.Text)
            BetsyPlot2 = retval
            Exit Function
        End If
    Next alayout
    MsgBox ("Betsy layout not found in the drawing!")
    BetsyPlot2 = retval
End Function
Shijith
Please advice how to plot a layout to a printer & its paper size which is not part of the layout page setup.
All example uses "dwg to pdf.pc3" but in my cas i had to use a system printer.
I just want to print to a system printer with default specification in the printer itself.
Please help.
Shijith
I solved my issue by creating a pc3 file for the printer and passing null to media.
Is there no aother way to specify a network or system printer.
Please advice.
Shijith
