Plot Preview from Database
lifanvc
Message 1 of 1
lifanvc
I want plot preview not open dwg file, I meet three questions, I need help ,thank you everyone.  this is very important for me,help please.
questions:
1.first plot not right;
2.close preview, Layout note the one before preview;
3.preview again ,it's right.
 public class Startup
        [CommandMethod("PlotPreView")]
        public void PlotPreView()
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            var acEdit = acDoc.Editor;
            using (DocumentLock acLckDoc = acDoc.LockDocument())
                var acDbSave = HostApplicationServices.WorkingDatabase;
                using (Database acDb = new Database(false, false))
                    var localFile = "E:\\plotprevie.dwg";
                    acDb.ReadDwgFile(localFile, FileOpenMode.OpenForReadAndAllShare, false, null);
                    acDb.CloseInput(true);
                    using (Transaction acTrans = acDb.TransactionManager.StartTransaction())
                        HostApplicationServices.WorkingDatabase = acDb;
                        LayoutManager acLayoutMgr = LayoutManager.Current;
                        // 1D4 64B
                        string handle = "1D4";
                        long lng = Convert.ToInt64(handle, 16);
                        ObjectId objectId = acDb.GetObjectId(false, new Handle(lng), 0);
                        if (objectId == null) return;
                        BlockReference acBrf = acTrans.GetObject(objectId, OpenMode.ForRead) as BlockReference;
                        if (acBrf == null) return;
                        BlockTableRecord acBlkTblRec = acTrans.GetObject(acBrf.OwnerId, OpenMode.ForRead) as BlockTableRecord;
                        Layout acLayout = acBlkTblRec.LayoutId.GetObject(OpenMode.ForWrite) as Layout;
                        acLayoutMgr.CurrentLayout = acLayout.LayoutName;
                        acLayoutMgr.SetCurrentLayoutId(acLayout.ObjectId);
                        acEdit.WriteMessage(acLayoutMgr.CurrentLayout + "3\n");
                        using (PlotInfo acPlInfo = new PlotInfo())
                            acPlInfo.Layout = acLayout.ObjectId;
                            // Get a copy of the PlotSettings from the layout
                            using (PlotSettings acPlSet = new PlotSettings(acLayout.ModelType))
                                acPlSet.CopyFrom(acLayout);
                                // Update the PlotSettings object
                                PlotSettingsValidator acPlSetVdr = PlotSettingsValidator.Current;
                                // Set the plot type
                                acPlSetVdr.SetPlotType(acPlSet, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
                                // Set the plot scale
                                acPlSetVdr.SetUseStandardScale(acPlSet, true);
                                acPlSetVdr.SetStdScaleType(acPlSet, StdScaleType.ScaleToFit);
                                // Center the plot
                                acPlSetVdr.SetPlotCentered(acPlSet, true);
                                // Set the plot device to use
                                acPlSetVdr.SetPlotConfigurationName(acPlSet, "DWF6 ePlot.pc3", "ANSI_A_(8.50_x_11.00_Inches)");
                                // Set the plot info as an override since it will
                                // not be saved back to the layout
                                acPlInfo.OverrideSettings = acPlSet;
                                // Validate the plot info
                                using (PlotInfoValidator acPlInfoVdr = new PlotInfoValidator())
                                    acPlInfoVdr.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
                                    acPlInfoVdr.Validate(acPlInfo);
                                    // Check to see if a plot is already in progress
                                    if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting)
                                        using (PlotEngine acPlEng = PlotFactory.CreatePreviewEngine((int)PreviewEngineFlags.Plot))
                                            // Track the plot progress with a Progress dialog
                                            using (PlotProgressDialog acPlProgDlg = new PlotProgressDialog(true, 1, true))
                                                using ((acPlProgDlg))
                                                    // Define the status messages to display
                                                    // when plotting starts
                                                    acPlProgDlg.set_PlotMsgString(PlotMessageIndex.DialogTitle, "Plot Progress");
                                                    acPlProgDlg.set_PlotMsgString(PlotMessageIndex.CancelJobButtonMessage, "Cancel Job");
                                                    acPlProgDlg.set_PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage, "Cancel Sheet");
                                                    acPlProgDlg.set_PlotMsgString(PlotMessageIndex.SheetSetProgressCaption, "Sheet Set Progress");
                                                    acPlProgDlg.set_PlotMsgString(PlotMessageIndex.SheetProgressCaption, "Sheet Progress");
                                                    // Set the plot progress range
                                                    acPlProgDlg.LowerPlotProgressRange = 0;
                                                    acPlProgDlg.UpperPlotProgressRange = 100;
                                                    acPlProgDlg.PlotProgressPos = 0;
                                                    // Display the Progress dialog
                                                    acPlProgDlg.OnBeginPlot();
                                                    acPlProgDlg.IsVisible = true;
                                                    // Start to plot the layout
                                                    acPlEng.BeginPlot(acPlProgDlg, null);
                                                    // Define the plot output
                                                    acPlEng.BeginDocument(acPlInfo, acDb.Filename, null, 1, false, null);
                                                    // Display information about the current plot
                                                    acPlProgDlg.set_PlotMsgString(PlotMessageIndex.Status, "Plotting: " + acDb.Filename + " - " + acLayout.LayoutName);
                                                    // Set the sheet progress range
                                                    acPlProgDlg.OnBeginSheet();
                                                    acPlProgDlg.LowerSheetProgressRange = 0;
                                                    acPlProgDlg.UpperSheetProgressRange = 100;
                                                    acPlProgDlg.SheetProgressPos = 0;
                                                    // Plot the first sheet/layout
                                                    using (PlotPageInfo acPlPageInfo = new PlotPageInfo())
                                                        acPlEng.BeginPage(acPlPageInfo, acPlInfo, true, null);
                                                    acPlEng.BeginGenerateGraphics(null);
                                                    acPlEng.EndGenerateGraphics(null);
                                                    // Finish plotting the sheet/layout
                                                    acPlEng.EndPage(null);
                                                    acPlProgDlg.SheetProgressPos = 100;
                                                    acPlProgDlg.OnEndSheet();
                                                    // Finish plotting the document
                                                    acPlEng.EndDocument(null);
                                                    // Finish the plot
                                                    acPlProgDlg.PlotProgressPos = 100;
                                                    acPlProgDlg.OnEndPlot();
                                                    acPlEng.EndPlot(null);
                        HostApplicationServices.WorkingDatabase = acDbSave;
 5previewagain.png4closefirstpreview.png3firstpreview.png2beforefirstpreview.png1dwg.png
Replies (0)
