Plot pagelayout error ,cad2016 is error,cad2018 and later is right
lifanvc
Message 1 of 8
lifanvc
I want plot from side database. cad2018、cad2019 plot ;but cad2016 error. any one can help me? this is very important for me ,please help me,thanks.
Document acDoc = AcApplication.DocumentManager.MdiActiveDocument;
            var fileName = @"E:\tadi\plottest.dwg";
            using (DocumentLock acLckDoc = acDoc.LockDocument())
                Database acDb = new Database(false, false);
                acDb.ReadDwgFile(fileName, FileOpenMode.OpenForReadAndAllShare, true, null);
                Database acDbSave = HostApplicationServices.WorkingDatabase;
                HostApplicationServices.WorkingDatabase = acDb;
                using (Transaction acTrans = acDb.TransactionManager.StartTransaction())
                    string handle = "64B";
                    long lng = Convert.ToInt64(handle, 16);
                    BlockReference acBrf = acTrans.GetObject(acDb.GetObjectId(false, new Handle(lng), 0), OpenMode.ForRead) as BlockReference;
                    BlockTableRecord acBlkTblRec = acTrans.GetObject(acBrf.OwnerId, OpenMode.ForRead) as BlockTableRecord;
                    Layout acLayout = acTrans.GetObject(acBlkTblRec.LayoutId, OpenMode.ForRead) as Layout;
                    LayoutManager.Current.CurrentLayout = acLayout.LayoutName;
                    PlotInfo acPlInfo = new PlotInfo();
                    acPlInfo.Layout = acLayout.ObjectId;
                    PlotSettings acPlSet = new PlotSettings(acLayout.ModelType);
                    acPlSet.CopyFrom(acLayout);
                    PlotSettingsValidator acPlSetVdr = PlotSettingsValidator.Current;
                    acPlSetVdr.SetPlotType(acPlSet,
                    Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
                    acPlSetVdr.SetUseStandardScale(acPlSet, true);
                    acPlSetVdr.SetStdScaleType(acPlSet, StdScaleType.ScaleToFit);
                    acPlSetVdr.SetPlotCentered(acPlSet, true);
                    acPlSetVdr.SetPlotConfigurationName(acPlSet, "DWG To PDF.pc3", "ANSI_A_(8.50_x_11.00_Inches)");
                    acPlInfo.OverrideSettings = acPlSet;
                    PlotInfoValidator acPlInfoVdr = new PlotInfoValidator();
                    acPlInfoVdr.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
                    acPlInfoVdr.Validate(acPlInfo);
                    if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting)
                        using (PlotEngine acPlEng = PlotFactory.CreatePublishEngine())
                            PlotProgressDialog acPlProgDlg = new PlotProgressDialog(false,
                            1,
                            true);
                            using (acPlProgDlg)
                                acPlProgDlg.set_PlotMsgString(PlotMessageIndex.DialogTitle,
                                "Plot Progress");
                                acPlProgDlg.set_PlotMsgString(PlotMessageIndex.CancelJobButtonMessage,
                                "Cancel Job");
                                acPlProgDlg.set_PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage,
                                "Cancel Sheet");
                                acPlProgDlg.set_PlotMsgString(PlotMessageIndex.SheetSetProgressCaption,
                                "Sheet Set Progress");
                                acPlProgDlg.set_PlotMsgString(PlotMessageIndex.SheetProgressCaption,
                                "Sheet Progress");
                                acPlProgDlg.LowerPlotProgressRange = 0;
                                acPlProgDlg.UpperPlotProgressRange = 100;
                                acPlProgDlg.PlotProgressPos = 0;
                                acPlProgDlg.OnBeginPlot();
                                acPlProgDlg.IsVisible = true;
                                acPlEng.BeginPlot(acPlProgDlg, null);
                                acPlEng.BeginDocument(acPlInfo,
                                acDoc.Name,
                                null,
                                1,
                                true,
                                "e:\\myplot");
                                acPlProgDlg.set_PlotMsgString(PlotMessageIndex.Status,
                                "Plotting: " + acDoc.Name + " - " +
                                acLayout.LayoutName);
                                acPlProgDlg.OnBeginSheet();
                                acPlProgDlg.LowerSheetProgressRange = 0;
                                acPlProgDlg.UpperSheetProgressRange = 100;
                                acPlProgDlg.SheetProgressPos = 0;
                                PlotPageInfo acPlPageInfo = new PlotPageInfo();
                                acPlEng.BeginPage(acPlPageInfo,
                                acPlInfo,
                                true,
                                null);
                                acPlEng.BeginGenerateGraphics(null); //  cad2016 error here
                                acPlEng.EndGenerateGraphics(null);
                                acPlEng.EndPage(null);
                                acPlProgDlg.SheetProgressPos = 100;
                                acPlProgDlg.OnEndSheet();
                                acPlEng.EndDocument(null);
                                acPlProgDlg.PlotProgressPos = 100;
                                acPlProgDlg.OnEndPlot();
                                acPlEng.EndPlot(null);
                HostApplicationServices.WorkingDatabase = acDbSave;
                acDb.Dispose();
Replies (7)
Message 2 of 8
_gile
Which version of the SDK (AutoCAD libraries) is your project targetting?
What is the error you get?
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
lifanvc
I use cad2016SDK。
the error:
thank you for your help
Message 4 of 8
lifanvc
the errors:1.png2.png3.png
Message 5 of 8
Alexander.Rivilis
@lifanvc
AutoCAD 2016 Service Pack 1 was installed?
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 6 of 8
lifanvc
not install sp1. install it and try again?
Message 7 of 8
lifanvc
I installed sp1,still the same error
Message 8 of 8
Alexander.Rivilis
This may be a bug that has been fixed in future releases of AutoCAD.
Expert Elite Member
