Please check the problem with this code. loop draw error.
mirwing76
mirwing76
one Circle Create OK! , next Circle Create Error!
Sub New(ByVal infoPipe As textProcess)
Dim drawCount As Integer
drawCount = infoPipe.circlePnt.Count
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
        Using tr As Transaction = db.TransactionManager.StartTransaction()
        Try
                For i = 0 To 0 'drawCount - 1
                        Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite, True, True)   '' Error Line
                        Dim objCircle As New Circle(infoPipe.circlePnt(i), Vector3d.ZAxis, infoPipe.circleSize(i) / 2)
                        btr.AppendEntity(objCircle)
                        tr.AddNewlyCreatedDBObject(objCircle, True)
                        tr.Commit()
                Next
        Catch ex As autodesk.AutoCAD.Runtime.Exception
                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Exception : " & ex.Message)
        Finally
                tr.Dispose()
        End Try
        End Using
End Sub
Please Help me.
_gile
What about instantiating the current space BlockTableRecord only once outside of the for loop?
Also, the two last arguments are superfluous (the current space cannot be erased or on a locked layer):
Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
sdphg
Try to move the tr.Commit() outside the loop. because once the transaction has been committed, you can't use it anymore.
 Try
Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite, True, True) For i = 0 To 0 'drawCount - 1 Dim objCircle As New Circle(infoPipe.circlePnt(i), Vector3d.ZAxis, infoPipe.circleSize(i) / 2) btr.AppendEntity(objCircle) tr.AddNewlyCreatedDBObject(objCircle, True) Next tr.Commit() Catch ex As autodesk.AutoCAD.Runtime.Exception
and _gile's advise also correct, if you move the commit outside the loop, that line may not throw exception, but you had better  move that line before the loop to avoid performance issue.
mirwing76
I solved it this way.
Thank you for your continued interest.
Public Class drawPipe
'Private _object As textProcess
Sub New(ByVal pipeInfo As textProcess)
    '_object = pipeInfo
    For i = 0 To pipeInfo.circlePnt.Count - 1
        cBlockTable(pipeInfo.circlePnt(i), pipeInfo.circleSize(i), pipeInfo.hasHatch(i))
    Next
End Sub
Sub cBlockTable(ByVal cntPnt As Point3d, ByVal dia As Double, ByVal hasHatch As Boolean)
    Dim radius As Double = dia / 2
        Try
            Dim objCircle As New Circle(cntPnt, Vector3d.ZAxis, radius)
            'Dim defNomal As Vector3d = Vector3d.ZAxis
            If hasHatch Then
                Dim objHatch As New Hatch()
                Dim idCircle As ObjectId = objCircle.ObjectId
                Dim idsCircle As New ObjectIdCollection()
                idsCircle.Add(idCircle)
                ' Create Hatch On objCircle
                objHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI31")
                objHatch.Normal = Vector3d.ZAxis
                objHatch.PatternScale = 3
                objHatch.Elevation = 0.0
                objHatch.AppendLoop(HatchLoopTypes.Default, idsCircle)
                btr.AppendEntity(objHatch)
                tr.AddNewlyCreatedDBObject(objHatch, True)
            End If
            tr.Commit()
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
            Finally
                tr.Dispose()
        End Try
    End Using
End Sub
End Class
mirwing76
