Place table using existing table style template (VB.net)
RodWing
RodWing
I'm trying to place a table using an existing table style that has 26 rows and 7 columns with the column header text defined. When I manually place a new table using that style it is placed as designed. Trying to place a new table using that style using the Sub below I don't get any of the formatting. It places a 1x1 table. Checking the proprties of the 1x1 table it lists the correct table style.
What am I missing?
Thanks.
 Sub PlaceTableTemplate(ByVal tsName As String)
        Dim doc As Document
        Dim db As Database
        doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        db = doc.Database
        Dim tsID As ObjectId
        Using tr As Transaction = db.TransactionManager.StartTransaction
            Dim stDict As DBDictionary = tr.GetObject(db.TableStyleDictionaryId, OpenMode.ForRead)
            If stDict.Contains(tsName) Then
                tsID = stDict.GetAt(tsName)
            Else
                MsgBox("Table style not found")
                Exit Sub
            End If
        End Using
        Dim ed As Editor
        Dim pr As PromptPointResult
        Dim tb As New Table
        ed = doc.Editor
        pr = ed.GetPoint(vbCrLf & "Enter table insertion point: ")
        If pr.Status = PromptStatus.OK Then
            With tb
                .TableStyle = tsID
                .Position = pr.Value
            End With
        Else
            Exit Sub
        End If
        tb.GenerateLayout()
        Using tr As Transaction = doc.TransactionManager.StartTransaction
            Dim bt As BlockTable = tr.GetObject(doc.Database.BlockTableId, OpenMode.ForRead)
            Dim btr As BlockTableRecord = tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
            btr.AppendEntity(tb)
            tr.AddNewlyCreatedDBObject(tb, True)
            tr.Commit()
        End Using
    End Sub
hgasty1001
Why the second transaction?, just delete the second transaction and commit the first transaction.
Gaston Nunez
RodWing
Gaston Nunez
Gaston, Thanks for the reply.
The reason for the second transaction is that I actually have this broken apart in separate classes. I combined the code from the different functions to create this sub to more easily illustrate what I'm trying to accomplish.
hgasty1001
But then,  you have to commit the first transaction too. I use this to create a table:
1.-Start a transaction
2.-Instance a new table
3.-Asign style and properties
4.-Generate layout
5.-Add to DB
6.-Commit the transaction
Gaston Nunez
SENL1362
Gaston,
I'll assume you assign the Styles (3.) separately to all the parts of the Instantiated table as i do.
In earlier experiments assigning the StyleId to the table didn't work for me either.
