passing late bound variant array to group
Message 1 of 1
I have some code that needs to late bind to AutoCAD ActiveX from VB Net (so that it works over many AutoCAD versions)
Most of the code works OK, but I am having difficulty adding entities to a group
I believe the problem is in the marshaling of the variant array.
Any suggestions on how to get this working?
'works correctly when using  early binding
Dim mygroup as AcadGroup
Dim mylist() as AcadEntity
mygroup = GroupColl.Add("Test 1")
redim mylist(0)
mylist(0) =   ActiveDocument.ModelSpace.AddLine(New Double() {0, 0, 0}, New Double() {1, 1, 1})
mygroup.AppendItems(mylist)
'fails using late binding, with error at AppendItems of "Invalid object array"
Dim mygroup as Object
Dim mylist() as Object         ' or Dim mylist as Object
redim mylist(0)
mylist(0) =   ActiveDocument.ModelSpace.AddLine(New Double() {0, 0, 0}, New Double() {1, 1, 0})
'have also tried  (following suggestions from MLeslie00 on this forum)
mygroup.AppendItems(MarshalVariantArray (mylist))
Public Function MarshalVariantStringArray(ByVal ObjIn AsObject) _
               As <Runtime.InteropServices.MarshalAsAttribute( _
                                   Runtime.InteropServices.UnmanagedType.SafeArray, _
                                   SafeArraySubType:=Runtime.InteropServices.VarEnum.VT_VARIANT)> Object
       ReturnObjIn
End Function
Replies (0)
