PaletteSet is not triggered by VS22.
jawadsjaber
Observer Observer
jawadsjaber
Observer
Observer
Hi
I am trying to play with one WPF sample, there is PaletteSet in it.
However, after loading the correct namespace, PaletteSet is not recognised. See below image
Is this because I use trial version of AutoCAD.
Alexander.Rivilis
It is look like you missing reference to  AcMgd.dll
Facebook | Twitter | LinkedIn
Expert Elite Member
jawadsjaber
Observer
Observer
Thanks a lot Alexander for your help.
It actually worked!
Norman_Yuan
Additional suggestions besides what Alexander has said:
1. Do not create a "raw" PaletteSet in the CommandClass/IExtensionApplication. Always subclass the PaletteSet for your own custom PaletteSet, wrap the code for creating itself inside and expose features required for business operation as properties/methods.
2. Unless you use very old AutoCAD (probably Acad2010 or older), there is no need to use System.Windows.Forms.Integration.ElementHost to add WPF UserControl to PaletteSet as Palette. WPF UserControl can be added as Palette with PaletteSet.AddVisual() method directly.
Something like:
public class MyPaletteSet : PaletteSet
    private MyWpfControl _palette;
   // Constructor
   public MyPaletteSet(...) : base(...)
      // set PaletteSet size/style/docking
      // Add WFP Palette
      _palette = new MyWpfControl();
      AddVisual("[palette name]", _palette);
   // you can expose the WFP control to outside as Property
   public MyWpfControl CustomPalette => _palette;
   // other properties/methods
Norman Yuan
Drive CAD With Code
jawadsjaber
Observer
Observer
Thanks @Norman_Yuan  for these great and professional advices.
Actually this sample was from AU2015..
If you can direct me to some samples based on the latest AutoCAD integration with WPF, it would be greatly appreciated as well.
