Palette with DataGridView
dennis
Advisor Advisor
dennis
I will try to explain what is happening without posting code, hopefully enough to get an idea as to what to do.
I have a custom palette set with one palette.  Think in comparison to the Xref Mgr.
The lower section is the Details (like the Xref Mgr), and I populate a DataGridView via a DataTable as the source.
When I first launch the palette, the DataGridView is transparent revealing the graphics in the drawing underneath it.  I can click around and it will refresh the Details.
Another thing, in that same Details DataGridView, if I use the horizontal scroll bar, the read out actually garbles up.  Similar effect if I stretch the palette.  I can then again, click around and it clears up.
Any suggestions would be appreciated.
CADbloke
WPF or Winforms? Got any code to show us?
working on all sorts of things including www.tvCAD.tv & www.CADreplace.com
dennis
I worked out the problem.  I was setting the background color via code, so I thought to set it instead in the CellStyle.  Once I removed the code setting and used the CellStyle instead, the anomaly went away.
