Override Save command
Message 1 of 10
Because a lot of our users are still on AutoCAD 2010, I have the requirement to be able to always save the drawings that are being worked on in 2015 down to 2010.  I want to make AutoCAD always save down to 2010 when using my .NET app.  I searched but could not find anything on exactly how you would accomplish that.  I can't just put a button on my form for user to push as I cannot be certain that they won't press the AutoCAD save instead.
Thanks!
Replies (9)
Message 2 of 10
Keith.Brown
Try the DefaultFormatForSave system variable. Just trap the save command using an event handler and set the variable before the save begins.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Changin...
Message 3 of 10
Hi there,
I cannot seem to find that setvar variable in the list.  When i try to type it in, AutoCAD 2015 does not recognize it.  Could it be called something else in 2015?
Message 4 of 10
Keith.Brown
It is a environment variable and not a system variable so you will not see it.
Check out this link.
http://blog.jtbworld.com/2005/11/set-environment-variable-using-vbnet.html
You might also check out this link.
https://msdn.microsoft.com/en-us/library/z46c489x.aspx
Message 5 of 10
I tried to make the environment variable idea work, but for some reason it is not reading it when it attempts to save.  Instead I am just going to wrap the save command into a function I have, but when I do a
acCurdb.SaveAs(acCurdb.Filename,DwgVersion.AC1024)
I get an error of eFileSharingViolation.  I am guessing because I am trying to do a saveas over the existing drawing.  If I cannot do a saveas over the existing drawing, how can I save the current drawing to 2010 format without renaming it as an alternate name.  That just won't work if I have to name the filename something else.
Message 6 of 10
Any ideas on this?
Message 7 of 10
Keith.Brown
Try saving the document instead of the database.
Here is a link to some code that does just that.
http://www.theswamp.org/index.php?topic=42016.0
p.s.  a simple google search of autocad .net save database turned up this answer.
Message 8 of 10
I am just finding that it does not help with the fact that I have to save the current document in a lower version.  See my code below to see what I am trying to do.  For the time being, all drawing files must be saved down to acad2010, and I cannot rely on the users to save down to 2010 on each exit... I am lucky to get them to save it period.  It causes massive problems specifically in the batch processing I run in acad2010 routines.
So I am trying to save down to 2010 through the document as you had suggested, and there is a function for doc.formatforsave, but I cannot find any help or details on this anywhere.  Could you please take a look at my code below and suggest what I should do to make it save down to 2010?
Dim acdoc As Document = Application.DocumentManager.MdiActiveDocument
Dim acCurdb As Database = acdoc.Database
Dim ed As Editor = acdoc.Editor
Using acdoc.LockDocument()
Dim acadDoc As Object = acdoc.FormatForSave()
acadDoc.Save()
end using
Message 9 of 10
Or could we use
Autodesk.AutoCAD.ApplicationServices.DocumentSaveFormat()?  Not sure which way makes the most sense.
Message 10 of 10
Is there a reason you don't just do it this way..?
<CommandMethod("CustomSave")> _
    Sub CSave()
        Dim CurDWG As Database = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database
        CurDWG.SaveAs(CurDWG.Filename, True, DwgVersion.AC1024, CurDWG.SecurityParameters)
    End Sub
just curious..
dwgversion list can be found here:
http://forums.autodesk.com/t5/net/how-to-determine-the-version-of-autocad-dwg-file-using-vb-net/td-p...
