Open User-Defined Version of AutoCAD Application using API
Mohamed_Arshad
Advisor Advisor
Mohamed_Arshad
HI Community,
About Plugin Functionality
    > My plugin will open AutoCAD Application externally and process the DWG File.
About the Query
    > I have multiple AutoCAD Versions installed in my PC, If I trigger the plugin last closed version of AutoCAD is opening.
   > How do open particular application using its version, It is possible to give the version number while opening the AutoCAD ?  any suggestion would be appreciate this.
Code Which I'm using to Open AutoCAD Application
Autodesk.AutoCAD.Interop.AcadApplication a = new Autodesk.AutoCAD.Interop.AcadApplication();
a.Visible = true;
@_gile @ActivistInvestor @kerry_w_brown @norman.yuan
Mohamed Arshad K
Software Developer (CAD & BIM)
norman.yuan
I do not understand: "My plugin" is PLUGIN for AutoCAD, it runs inside AutoCAD, Or, to say in different way: it only lives when AutoCAD runs and your plugin is loaded. So, why you want use code (your plugin code!) from a running AutoCAD to start another AutoCAD session?
Norman Yuan
Drive CAD With Code
Mohamed_Arshad
HI @norman.yuan  Thank you fast respond 🙂
   Sorry for the misunderstanding. the plugin which I have created (MyPlugin) is inside the Revit. From Revit I'm triggering AutoCAD Application, Here I need to open the AutoCAD according to version. I hope this will make a better understanding for you 🙂
Mohamed Arshad K
_gile
Have a look at this topic.
The 'progId' argument allows to start the last closed AutoCAD version ("AutoCAD.Application") or a spcecific version ("AutoCAD.Application.24.3").
Gilles Chanteau
GileCAD
GitHub
Mohamed_Arshad
HI @_gile
It worked Thank you !!
Mohamed Arshad K
