Offset polyline by pick point on side like autocad
ditran7577
Message 1 of 23
ditran7577
Hi pro,
Please let me know how to offset a opened polyline by pick point on side of opened polyline.
Replies (22)
Message 2 of 23
Alexander.Rivilis
With minimum error checking. Only as idea.
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
[assembly: CommandClass(typeof(Rivilis.CurveUtils))]
namespace Rivilis
  public class CurveUtils
    [CommandMethod("OffsetCurve", CommandFlags.Modal)]
    public static void OffsetCurve()
      Document doc = Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      PromptDoubleResult resValueOff = ed.GetDistance("\nOffset value: ");
      if (resValueOff.Status != PromptStatus.OK) return;
      PromptPointResult  resPointOff = ed.GetPoint("\nOffset side: ");
      if (resPointOff.Status != PromptStatus.OK) return;
      PromptEntityOptions prCurv = new PromptEntityOptions("\nSelect curve: ");
      prCurv.SetRejectMessage("not a Curve");
      prCurv.AddAllowedClass(typeof(Curve),false);
      PromptEntityResult resCurv = ed.GetEntity(prCurv);
      if (resCurv.Status != PromptStatus.OK) return;
      using  (Transaction tr = doc.TransactionManager.StartTransaction()) {
        Curve curve = tr.GetObject(resCurv.ObjectId, OpenMode.ForRead) as Curve;
        if (curve != null) {
          BlockTableRecord btr = tr.GetObject(curve.BlockId, OpenMode.ForWrite) as BlockTableRecord;
          if (btr != null) {
            Point3d pDir = (Point3d)(Application.GetSystemVariable("VIEWDIR"));
            if (pDir != null) {
              Point3d pWCS = resPointOff.Value.TransformBy(ed.CurrentUserCoordinateSystem);
              double offset = IsRightDirection(curve, pWCS, pDir.GetAsVector()) ? resValueOff.Value : -resValueOff.Value;
              DBObjectCollection curvCols = curve.GetOffsetCurves(offset);
              foreach (DBObject obj in curvCols) {
                Curve subCurv = obj as Curve;
                if (subCurv != null) {
                  btr.AppendEntity(subCurv);
                  tr.AddNewlyCreatedDBObject(subCurv, true);
        tr.Commit();
    // Detect side of point
    public static bool IsRightDirection(Curve pCurv, Point3d p, Vector3d vDir)
      Vector3d vNormal = Vector3d.ZAxis;
      if (pCurv.IsPlanar) {
        Plane plane = pCurv.GetPlane();
        vNormal = plane.Normal;
        p = p.Project(plane, vDir);
      Point3d pNear = pCurv.GetClosestPointTo(p, true);
      Vector3d vSide = p - pNear;
      Vector3d vDeriv = pCurv.GetFirstDerivative(pNear);
      if (vNormal.CrossProduct(vDeriv).DotProduct(vSide) < 0.0)
        return true;
      else
        return false;
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 23
Hallex
Nice solution
Hats off
Cheers 🙂
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 4 of 23
ditran7577
Great.It worked OK.
Thank Rivilis,
Message 5 of 23
Hello Rivilis,
Thank you for the code, it works perfect with polyline and circle I tried but works inverse in case of line.
How can I solve this?
Message 6 of 23
FRFR1426
From ARX docs:
> AcDbCurve::getOffsetCurves
> If the offsetDist value is negative, it is usually interpreted as being an offset to make a smaller curve (that is, for an arc it would offset to a radius that is offsetDist less than the starting curve's radius). If the negative value has no meaning in terms of making the curve smaller, a negative offsetDist may be interpreted as an offset in the direction of smaller X,Y,Z WCS coordinates. This is not enforced, so custom entities can interpret the sign of the offsetDist value however they want.
So you can not know where the offset curves will go. You have to offset, then check if the new curves are on the desired side and if not, negate the offset.
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
Message 7 of 23
5thSth
had trouble with the suggested solution(need to brush up on my math), but I have devised a method that worked with different entities:
        public static bool IsRightDirection2(Curve pCurv, Point3d picked) //picked - picked point (not point on curve)
            Point3d pOnCurve = pCurv.GetClosestPointTo(picked, false);
            var dist = picked.DistanceTo(pOnCurve);
            double distCheck = new double();
            DBObjectCollection acDbObjColl = pCurv.GetOffsetCurves(dist);
            foreach (Entity acEnt in acDbObjColl)
                Curve testCurve = acEnt as Curve;
                distCheck = picked.DistanceTo(testCurve.GetClosestPointTo(picked, false));
            if (distCheck == 0)
                return true;
            else
                return false;
I still need to do some bug testing, and to be safe, you can implement the planar check from previous solution.
basically, it creates a temporary object offset-ed at small distance, and checks if distance from the new object to that point is 0. (if not 0, means its on the opposite side of the object).
Message 8 of 23
Hate to wake up an old post, but it is one of the closer relevant posts to what I need. I'm a newer programmer trying to work a set of tools and was wondering if anyone could help me do this same style of function in VB.NET rather than C#.NET?
I already have it set to create a line from point a (User Selected) to point b (Also user selected), and have it offset 1 foot, but I need it to offset in a specific direction.
Namespace Tools
    Public Class Commands
        <CommandMethod("OffSeC")>
        Public Sub OffSeC()
            '' Get the current document and database
            Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
            Dim acCurDb As Database = acDoc.Database
            Dim pPtRes As PromptPointResult
            Dim pPtOpts As PromptPointOptions = New PromptPointOptions("")
            '' This asks for the Dead.
            pPtOpts.Message = vbLf & "Choose Dead."
            pPtRes = acDoc.Editor.GetPoint(pPtOpts)
            Dim ptDead As Point3d = pPtRes.Value
            '' Emergency Exit Here!
            If pPtRes.Status = PromptStatus.Cancel Then Exit Sub
            '' This asks for the Live.
            pPtOpts.Message = vbLf & "Live?"
            pPtOpts.UseBasePoint = True
            pPtOpts.BasePoint = ptDead
            Dim ptLive As Point3d = pPtRes.Value
            '' Emergency Exit Numero Dos!
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                '' Open the Block Table for read.
                Dim acBlkTbl As BlockTable
                acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                '' Open the Block table record Model space for write
                Dim acBlkTblRec As BlockTableRecord
                acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                Using acLine As Line = New Line(ptDead, ptLive)
                    acBlkTblRec.AppendEntity(acLine)
                    acTrans.AddNewlyCreatedDBObject(acLine, True)
                    Dim acDbObjColl As DBObjectCollection = acLine.GetOffsetCurves(12)
                    For Each acEnt As Entity In acDbObjColl
                        acBlkTblRec.AppendEntity(acEnt)
                        acTrans.AddNewlyCreatedDBObject(acEnt, True)
                    Next
                End Using
                acTrans.Commit()
            End Using
        End Sub
    End Class
End Namespace
Message 9 of 23
FRFR1426
To offset a line, you only need to translate the two end points, it's trivial. The GetSecondDerivative function should return you a vector perpendicular to your line. Not sure, but it should be an unit vector. After that, you multiply this vector with your offset and you add it to the end points:
Dim v As Vector3d = line.GetSecondDerivative(0) * offset
Dim newLine As New Line(line.StartPoint + v, line.EndPoint + v)
Maxence DELANNOY
Manager
http://wiip.fr
Message 10 of 23
But wouldn't that Offset the line to the point clicked? Rather than offset it the one foot as it already does?
Message 11 of 23
FRFR1426
To check the side, you can use a cross product between a vector starting from the start of your line to the point clicked by the user and the line direction vector. The Z coordinate will be positive if the point clicked by the user is on the left of the line, negative if it is on the right.
Maxence DELANNOY
Manager
http://wiip.fr
Message 12 of 23
Well, now the issue I keep running into is Line.GetSecondDerivative(0). where GetSecondDerivative spits out the "Cannot access function" error.  Would I need to import anything other than these?
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Message 13 of 23
FRFR1426
GetSecondDerivative is an instance method of the Autodesk.AutoCAD.DatabaseServices.Curve class, so if you have a Autodesk.AutoCAD.DatabaseServices import, it should be OK.
Maxence DELANNOY
Manager
http://wiip.fr
Message 14 of 23
Alexander.Rivilis
As far as I remember GetSecondDerivative for Line and stretch segment of polyline return zero-vector.
On this picture 1 - First Derivative, 2 - Second Derivative:
Expert Elite Member
Message 15 of 23
FRFR1426
Yes, it's because lines have no curvature, so there is an infinity of second derivatives. You can use instead:
(line.EndPoint - line.StartPoint).GetPerpendicularVector()
Maxence DELANNOY
Manager
http://wiip.fr
Message 16 of 23
5thSth
I cant help you with VB, but I can give you my complete code for c#.
there are online translators C# to VB that could do the translating for ya. http://converter.telerik.com/ 4 example.
this was a jig class that would do the realtime offset preview. I was newb back then(still am), and I'm not sure if I finished everything I had planned, but here's the code I have.
basically, it would
a) project the offset line
b) check to see if the offset line is there where it's supposed to be
c) if its not there, flip the direction
using System;
using System.Collections.Generic;
//using System.Linq;
//using System.Text;
namespace myOffset
    public class myOffsetJig : DrawJig
        #region fields
        private Point3d jigOnLinePt;
        private Point3d selectedPt;
        private Polyline myPoly;
        //private double myAngle;
        private double myDist;
        private Entity theEntity;
        public Entity testCurve;
        private List<double> myOffsets = new List<double>() { 0, 5, 10, 15 };
        private Matrix3d myPointUCS;
        #endregion
        #region constructor
        public myOffsetJig(Point3d onLinePt, Point3d picked, Polyline myPolyline, Matrix3d pointUCS)
            jigOnLinePt = onLinePt;
            selectedPt = picked.TransformBy(UCS);
            myPoly = myPolyline;
            myPointUCS = pointUCS;
            //myAngle = angle;
        #endregion
        #region properties
        public double Distance
            get { return myDist; }
            set { myDist = value; }
        public Matrix3d UCS
            get
                return Application.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem;
        #endregion
        #region offet
        public Entity offsetPoly
            get
                DBObjectCollection acDbObjColl = myPoly.GetOffsetCurves(myDist);
                    theEntity = acEnt;
                theEntity.ColorIndex = 4;
                return theEntity;
        #endregion
        #region // Detect side of point¸2
        public static bool IsRightDirection2(Curve pCurv, Point3d picked/*, Vector3d vDir*/)
            if (distCheck == 0)
                return true;
            else
                return false;
        #endregion
        #region WorldDraw
        protected override bool WorldDraw(Autodesk.AutoCAD.GraphicsInterface.WorldDraw draw)
            //Matrix3d mat = Matrix3d.Displacement(mBase.GetVectorTo(mLocation));
            Autodesk.AutoCAD.GraphicsInterface.WorldGeometry geo = draw.Geometry;
            if (geo != null)
                geo.Draw(offsetPoly);
                foreach (var offset in myOffsets)
                    var myEnt = offsetWidget.drawLine(offset);
                    myEnt.TransformBy(myPointUCS);
                    myEnt.ColorIndex = 4;
                    myEnt.IsContentSnappable();
                    geo.Draw(myEnt);
                //geo.PushModelTransform(mat);
                //geo.PopModelTransform();
            return true;
        #endregion
        #region SamplerStatus
        protected override SamplerStatus Sampler(JigPrompts prompts)
            JigPromptPointOptions prDistOpt = new JigPromptPointOptions("\nInput offset");
            prDistOpt.BasePoint = jigOnLinePt;
            prDistOpt.UseBasePoint = true;
            //prDistOpt.Cursor = CursorType.Parallelogram;
            var prDist = prompts.AcquirePoint((JigPromptPointOptions)prDistOpt);
            if (prDist.Status == PromptStatus.Cancel || prDist.Status == PromptStatus.Error)
                return SamplerStatus.Cancel;
            if (!prDist.Equals(0))
                myDist = prDist.Value.TransformBy(myPointUCS.Inverse()).Y;
                myDist = IsRightDirection2(myPoly, selectedPt /*, pDir.GetAsVector()*/) ? myDist : -myDist;
                return SamplerStatus.OK;
            else
                return SamplerStatus.NoChange;
        #endregion
        #region Initialize Jig
        //[CommandMethod("OffsetJig")]
        public void OffsetJigCommand()
            try
                Database db = HostApplicationServices.WorkingDatabase;
                Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    PromptResult jigRes = Application.DocumentManager.MdiActiveDocument.Editor.Drag(this);
                    if (jigRes.Status == PromptStatus.OK)
                        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                            // Add each offset object
                            btr.AppendEntity(acEnt);
                            tr.AddNewlyCreatedDBObject(acEnt, true);
                        tr.Commit();
                    else
                        tr.Abort();
        #endregion
            #region exception
            catch (System.Exception ex)
                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.ToString());
            #endregion
p.s. thanks giles for transformation matrix
Message 17 of 23
using System;
namespace Rivilis
          if (btr != null) {
            if (pDir != null) {
        tr.Commit();
        return true;
      else
        return false;
So, I ended up using this, kind of, but I have to click the opposite side for it to offset properly, is there anyway to counteract this?
Message 18 of 23
got some time to play, test the code below, hth.
                            var curve1 = curve.GetOffsetCurves(-resValueOff.Value)[0] as Curve;
                            var curve2 = curve.GetOffsetCurves(resValueOff.Value)[0] as Curve;
                            if (curve1 != null && curve2 != null)
                                var givenPoint = resPointOff.Value;
                                if (curve1.GetClosestPointTo(givenPoint, false).DistanceTo(givenPoint) <
                                    curve2.GetClosestPointTo(givenPoint, false).DistanceTo(givenPoint))
                                    btr.AppendEntity(curve1);
                                    tr.AddNewlyCreatedDBObject(curve1, true);
                                else
                                    btr.AppendEntity(curve2);
                                    tr.AddNewlyCreatedDBObject(curve2, true);
                            //DBObjectCollection curvCols = curve.GetOffsetCurves(offset);
                            //foreach (DBObject obj in curvCols)
                            //    Curve subCurv = obj as Curve;
                            //    if (subCurv != null)
                            //        btr.AppendEntity(subCurv);
                            //        tr.AddNewlyCreatedDBObject(subCurv, true);
Message 19 of 23
_gile
Maybe you can get some inspiration from this.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 20 of 23
This is the shortest code and easiest way for me to make it work!
[CommandMethod("OffsetPolyLine")]
public void OffsetPlines(object obj)
Database db = doc.Database;
CivilDocument cdoc = CivilApplication.ActiveDocument;
//select ROW polyline prompt
PromptEntityOptions peo = new PromptEntityOptions("\nSelect ROW polyline:");
peo.SetRejectMessage("\nSelected entity is not a curve");
peo.AddAllowedClass(typeof(Curve), false);
peo.AllowNone = true;
PromptEntityResult per = ed.GetEntity(peo);
if (per.Status == PromptStatus.Cancel) return;
while (per.Status == PromptStatus.OK)
using (DocumentLock dl = doc.LockDocument())
//prompt to specify offset distance
PromptDoubleOptions pdo = new PromptDoubleOptions("\nSpecify the offset distance:");
pdo.AllowNegative = false;
pdo.AllowZero = false;
pdo.DefaultValue = 10;
pdo.UseDefaultValue = true;
PromptDoubleResult pdr = ed.GetDouble(pdo);
double distance = pdr.Value;
if (pdr.Status == PromptStatus.Cancel) return;
//prompt to select side
PromptPointResult ppr = ed.GetPoint("\nSelect side to offset to:");
if (ppr.Status == PromptStatus.Cancel) return;
Polyline pl = (Polyline) tr.GetObject(per.ObjectId, OpenMode.ForRead);
Point3d cp = pl.GetClosestPointTo(ppr.Value, false);
DBObjectCollection offsetCurvesCollection1 = pl.GetOffsetCurves(distance);
DBObjectCollection offsetCurvesCollection2 = pl.GetOffsetCurves(-distance);
Curve curve1 = null;
Curve curve2 = null;
Point3d p1 = new Point3d();
Point3d p2 = new Point3d();
double dist1 = 0;
double dist2 = 0;
for (int i = 0; i < offsetCurvesCollection1.Count; i++)
curve1 = (Curve) offsetCurvesCollection1[i];
curve2 = (Curve) offsetCurvesCollection2[i];
p1 = curve1.GetClosestPointTo(ppr.Value, false);
p2 = curve2.GetClosestPointTo(ppr.Value, false);
dist1 = p1.DistanceTo(ppr.Value);
dist2 = p2.DistanceTo(ppr.Value);
if (dist1 < dist2)
AcadUtilities.PlaceEntityinDrawing(curve1);
else
AcadUtilities.PlaceEntityinDrawing(curve2);
tr.Commit();
