ObjectID and general help!
I have the following snippet.
GetTheObj returns the selected object's ID
Dim
myVportID As DatabaseServices.ObjectId
GetTheObj(nmyVportID,"VIEWPORT")
Dim S1 As String
S1 ="%<\AcObjProp Object(%<\_ObjId" & myVportID.ToString & ">%).CustomScale \f ""%lu2%qf2816"">% "
the problem is that myVportID.ToString return my ID # in brackets i.e. (9183278172)
And on another note where can I find help on all the different methods and properties etc on the Adesk stuff (yes very technical term)
I looked in the Object Browser in my VS 2010 and there is not much nothing there.
I am sure it is just me. I am migrating from VBA.
Here are two different ways to do it, there are more
 Dim myVportIdToString As String = "(9183278172)"
        Dim useSubStringMethod As String = myVportIdToString.Substring(1, myVportIdToString.Length - 2)
        Dim useRemoveMethod As String = myVportIdToString.Remove(myVportIdToString.Length - 1).Remove(0, 1)
        ''''useSubStringMethod & useRemoveMethod = 9183278172
Thanks Jeffrey
That works
I just thought that I was missing something in the method
Odd why it would return a string closed in brackets.
My LISP days came rushing in, thought I may have to (setq A (car myVportIdToString.Substring))
all the same thanks again.
any idea in regards to help on all the different methods, or do they just not exists.
Go to where you installed ObjectARX SDK or here http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1911627
In there is a docs folder.
I use arxdoc.chm which contains the arxmgd.chm(.NET), but the arxdoc.chm has alot more info in it.
I tend to use the index tab mostly.
thanks Jeffrey
this is great stuff
on a side note, apprently
myVportID.OldIdPtr.ToString()
returns the object id string without the brackets.
That seems to be a better way
Thanks for the info
