ObjectId and ElementId
Hi Team,
I am use to develop one web app using Forge API.
its working well and good. at the same time am using design automation in forge. i can able to create Package its working fine.
i will process the dwg file using forge api preparing to viewer. I can able to view dwg in browser.
my issue is i have viewer click event the event click populate the element id.
but my package i can get only the object id. element id and object id totally different.
please advice me what is the conman id each object client and server side.
Summery: when user click the object in viewer i wan to capture id and store my local database. and using package i need to process the user clicked object.
Example: when user click the drawing number in viewer. from the next time i want change the drawing number dynamically using call packge from c# code .
Please advice me ASAP.
Ragunath.S
moogalm
Autodesk Support
Autodesk Support
I suggest you posting this same query on Stackoverflow, with Forge Viewer and Design Automation, my colleagues will certainly help. for all queries related Forge are through well know StackOverFlow platform.
moogalm
Autodesk Support
Autodesk Support
I mean add Forge Viewer and Forge Design Automation as Tag when you post to SFO, this will alert for Forge experts.
