null reference could result
I know some people don't like to see questions here that include any com
interop elements, but this is a dotnet question so does not belong in the
vba group.
acad2009 vbnet 2008 express
how to avoid the compiler warning:
Variable 'ArrayObjects' is used before it has been assigned a value. A null
reference exception could result at runtime.
given
Dim ArrayObjects() As AcadEntity
...some code...
Try
ReDim ArrayObjects(0)
ArrayObjects(UBound(ArrayObjects)) = oSideLine
Catch ex As ApplicationException
m_Util.Logentry("error " & ex.Message)
End Try
...more code...then...
Try
If ArrayObjects Is Nothing Then <------------here is the warning location at
"ArrayObjects"
m_Util.Logentry("error ArrayObjects Is Nothing")
Else
SelectionSetWblock.AddItems(ArrayObjects)
End If
End Try
what should I be doing in such cases (using an array)
i wouldn't think you'd do Dim ArrayObjects() As AcadEntity = Nothing
like you might with a simple object???
thanks
mark
A 'dotnet question' will probably get more answers on
the relevant Microsoft newsgroups.
This isn't a quesiton about using the managed .NET API,
it is a basic VB.NET language usage question.
I'm sure someone here that's more familiar with VB.NET
will answer you, but I generally don't answer basic language
usage questions here, because this really isn't the VB.NET
(or C#) language newsgroup, this newsgroup is about using
the managed AutoCAD API.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2011
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
"mp" wrote in message
news:6368878@discussion.autodesk.com...
vba group.
given
...some code...
Try
End Try
Try
"ArrayObjects"
Else
End If
End Try
thanks
mark
