[No Subject]
[No Subject]
Message 1 of 1
[No Subject]
I am having trouble looping through my code until the
user is done with the command.  What this routine does is to ask the user
what axis is being halved (i.e. in which axis is the diameter) and then
continues to ask the user for the coordinates until the user escapes, or enters
a null value.
The code works fine the first time through, but on
the first loop (second time asking for the coordinates), I get an
eNotOpenForWrite error and AutoCAD crashes.  Can anyone point me in the
direction that's causing this?
Below is my code. Obviously, one would have to create
a CommandMethod before running this, but I figured I didn't have to supply it as
that code does is point to this code.
Imports acadApp =
Autodesk.AutoCAD.ApplicationServices
Imports acadDB =
Autodesk.AutoCAD.DatabaseServices
Imports acadED =
Autodesk.AutoCAD.EditorInput
Imports acadGo = Autodesk.AutoCAD.Geometry
Imports acadRT = Autodesk.AutoCAD.Runtime
Module Coordinates
Dim CurrentStack As
System.Diagnostics.StackTrace
Public Sub Coordinates()
' declare local variables
Dim doc As acadApp.Document = _
size=2>acadApp.Application.DocumentManager.MdiActiveDocument
Dim ed As acadED.Editor = doc.Editor
Dim db As acadDB.Database = doc.Database
Dim tr As Transaction =
db.TransactionManager.StartTransaction
Dim btr As BlockTableRecord
Dim docLock As acadApp.DocumentLock = _
doc.LockDocument(acadApp.DocumentLockMode.AutoWrite,
"Coords", "Coords", True)
'Dim docLock As acadApp.DocumentLock =
doc.LockDocument
Dim ValueEntered As Boolean
Dim pdMode As Integer =
ed.Document.Database.Pdmode
Dim pdSize As Double =
ed.Document.Database.Pdsize
Dim ptOrigin As acadGo.Point3d =
ed.Document.Database.Ucsorg
Dim UCSIcon As Object =
acadApp.Application.GetSystemVariable("UCSICON")
Try
acadApp.Application.SetSystemVariable("PDMODE",
35)
acadApp.Application.SetSystemVariable("PDSIZE",
0.25)
Begin:
acadApp.Application.SetSystemVariable("UCSICON",
1)
ValueEntered = True
btr = DirectCast( _
tr.GetObject(doc.Database.CurrentSpaceId,
acadDB.OpenMode.ForWrite), _
BlockTableRecord)
' Prompt the user to input any of the
keywords
Dim keyOptions As acadED.PromptKeywordOptions =
_
New acadED.PromptKeywordOptions(Environment.NewLine +
_
"Select the axis to be halved: ")
keyOptions.Keywords.Add("X")
keyOptions.Keywords.Add("Y")
keyOptions.Keywords.Add("None")
keyOptions.Keywords.Add("All")
keyOptions.Keywords.Add("Done")
keyOptions.Keywords.Default =
My.Settings.AxisToHalve
Dim HalfAxis As acadED.PromptResult =
ed.GetKeywords(keyOptions)
If (HalfAxis.Status = PromptStatus.Keyword) Or
_
(HalfAxis.Status = PromptStatus.OK) Then
If HalfAxis.StringResult <> "Done"
Then
' Store default AxisToHalve
My.Settings.AxisToHalve =
Do Until ValueEntered = False
' Get the X coordinate
Dim pointX As acadED.PromptDoubleResult =
_
ed.GetDouble(Environment.NewLine + "Enter X
coordinate: ")
If (pointX.Status <> PromptStatus.OK)
Then
'Exit Do
' Get the Y coordinate
Dim pointY As acadED.PromptDoubleResult =
_
ed.GetDouble(Environment.NewLine + "Enter Y
coordinate: ")
If (pointY.Status <> PromptStatus.OK)
Then
'Exit Do
Dim myPoint As acadGo.Point3d
Select Case HalfAxis.StringResult
Case "X"
myPoint = New acadGo.Point3d(pointX.Value / 2,
pointY.Value, 0)
Case "Y"
myPoint = New acadGo.Point3d(pointX.Value,
pointY.Value / 2, 0)
Case "All"
Case Else
pointY.Value, 0)
End Select
Dim dbpt As acadDB.DBPoint = New
acadDB.DBPoint(myPoint)
'dbpt.SetDatabaseDefaults(db)
btr.AppendEntity(dbpt)
tr.AddNewlyCreatedDBObject(dbpt, True)
tr.Commit()
Loop
GoTo Begin
Catch acEx As acadRT.Exception
MsgBox(CurrentStack.GetFrame(0).GetFileLineNumber +
": " + acEx.Message, _
MsgBoxStyle.OkOnly + MsgBoxStyle.Critical,
_
acEx.ErrorStatus.ToString())
tr.Abort()
Catch nullEx As
System.NullReferenceException
Catch ex As System.Exception
": " + ex.Message, _
MsgBoxStyle.Critical + MsgBoxStyle.Critical,
_
ex.InnerException.ToString())
tr.Abort()
Finally
' reset variables to original state
pdMode)
pdSize)
'acadApp.Application.SetSystemVariable("UCSICON",
sUCSIcon)
'acadApp.Application.SetSystemVariable("UCSORG",
ptOrigin)
docLock.Dispose()
End Try
End Sub
End Module
Replies (0)
