Problem looping through code more than once.
Sorry, I forgot the subject last time around
I am having trouble looping through my code until the user is done with the
command. What this routine does is to ask the user what axis is being
halved (i.e. in which axis is the diameter) and then continues to ask the
user for the coordinates until the user escapes, or enters a null value.
The code works fine the first time through, but on the first loop (second
time asking for the coordinates), I get an eNotOpenForWrite error and
AutoCAD crashes. Can anyone point me in the direction that's causing this?
Below is my code. Obviously, one would have to create a CommandMethod before
running this, but I figured I didn't have to supply it as that code does is
point to this code.
Imports acadApp = Autodesk.AutoCAD.ApplicationServices
Imports acadDB = Autodesk.AutoCAD.DatabaseServices
Imports acadED = Autodesk.AutoCAD.EditorInput
Imports acadGo = Autodesk.AutoCAD.Geometry
Imports acadRT = Autodesk.AutoCAD.Runtime
Module Coordinates
Dim CurrentStack As System.Diagnostics.StackTrace
Public Sub Coordinates()
' declare local variables
Dim doc As acadApp.Document = _
acadApp.Application.DocumentManager.MdiActiveDocument
Dim ed As acadED.Editor = doc.Editor
Dim db As acadDB.Database = doc.Database
Dim tr As Transaction = db.TransactionManager.StartTransaction
Dim btr As BlockTableRecord
Dim docLock As acadApp.DocumentLock = _
doc.LockDocument(acadApp.DocumentLockMode.AutoWrite, "Coords", "Coords",
True)
'Dim docLock As acadApp.DocumentLock = doc.LockDocument
Dim ValueEntered As Boolean
Dim pdMode As Integer = ed.Document.Database.Pdmode
Dim pdSize As Double = ed.Document.Database.Pdsize
Dim ptOrigin As acadGo.Point3d = ed.Document.Database.Ucsorg
Dim UCSIcon As Object = acadApp.Application.GetSystemVariable("UCSICON")
Try
acadApp.Application.SetSystemVariable("PDMODE", 35)
acadApp.Application.SetSystemVariable("PDSIZE", 0.25)
Begin:
acadApp.Application.SetSystemVariable("UCSICON", 1)
ValueEntered = True
btr = DirectCast( _
tr.GetObject(doc.Database.CurrentSpaceId, acadDB.OpenMode.ForWrite), _
BlockTableRecord)
' Prompt the user to input any of the keywords
Dim keyOptions As acadED.PromptKeywordOptions = _
New acadED.PromptKeywordOptions(Environment.NewLine + _
"Select the axis to be halved: ")
keyOptions.Keywords.Add("X")
keyOptions.Keywords.Add("Y")
keyOptions.Keywords.Add("None")
keyOptions.Keywords.Add("All")
keyOptions.Keywords.Add("Done")
keyOptions.Keywords.Default = My.Settings.AxisToHalve
Dim HalfAxis As acadED.PromptResult = ed.GetKeywords(keyOptions)
If (HalfAxis.Status = PromptStatus.Keyword) Or _
(HalfAxis.Status = PromptStatus.OK) Then
If HalfAxis.StringResult <> "Done" Then
' Store default AxisToHalve
My.Settings.AxisToHalve = HalfAxis.StringResult
Do Until ValueEntered = False
' Get the X coordinate
Dim pointX As acadED.PromptDoubleResult = _
ed.GetDouble(Environment.NewLine + "Enter X coordinate: ")
If (pointX.Status <> PromptStatus.OK) Then
'Exit Do
' Get the Y coordinate
Dim pointY As acadED.PromptDoubleResult = _
ed.GetDouble(Environment.NewLine + "Enter Y coordinate: ")
If (pointY.Status <> PromptStatus.OK) Then
'Exit Do
Dim myPoint As acadGo.Point3d
Select Case HalfAxis.StringResult
Case "X"
myPoint = New acadGo.Point3d(pointX.Value / 2, pointY.Value, 0)
Case "Y"
myPoint = New acadGo.Point3d(pointX.Value, pointY.Value / 2, 0)
Case "All"
myPoint = New acadGo.Point3d(pointX.Value / 2, pointY.Value / 2, 0)
Case Else
myPoint = New acadGo.Point3d(pointX.Value, pointY.Value, 0)
End Select
Dim dbpt As acadDB.DBPoint = New acadDB.DBPoint(myPoint)
'dbpt.SetDatabaseDefaults(db)
btr.AppendEntity(dbpt)
tr.AddNewlyCreatedDBObject(dbpt, True)
tr.Commit()
Loop
GoTo Begin
Catch acEx As acadRT.Exception
MsgBox(CurrentStack.GetFrame(0).GetFileLineNumber + ": " + acEx.Message, _
MsgBoxStyle.OkOnly + MsgBoxStyle.Critical, _
acEx.ErrorStatus.ToString())
tr.Abort()
Catch nullEx As System.NullReferenceException
Catch ex As System.Exception
MsgBox(CurrentStack.GetFrame(0).GetFileLineNumber + ": " + ex.Message, _
MsgBoxStyle.Critical + MsgBoxStyle.Critical, _
ex.InnerException.ToString())
tr.Abort()
Finally
' reset variables to original state
acadApp.Application.SetSystemVariable("PDMODE", pdMode)
acadApp.Application.SetSystemVariable("PDSIZE", pdSize)
'acadApp.Application.SetSystemVariable("UCSICON", sUCSIcon)
'acadApp.Application.SetSystemVariable("UCSORG", ptOrigin)
docLock.Dispose()
End Try
End Sub
End Module
Hi Nathan.
Dont do the Transaction.Commit() in the loop, do it after you are done with
the loop.
Regards
Peter
"Nathan Guill" wrote in message
news:5622674@discussion.autodesk.com...
point to this code.
Module Coordinates
True)
Try
Begin:
ValueEntered = True
btr = DirectCast( _
BlockTableRecord)
'Exit Do
'Exit Do
Case "X"
Case "Y"
Case "All"
Case Else
End Select
tr.Commit()
Loop
GoTo Begin
tr.Abort()
tr.Abort()
Finally
docLock.Dispose()
End Try
End Sub
End Module
All right, placing my Transaction.Commit() statement after my loop changes
my problem to the user no longer sees the points being placed as they are
entered. How do I make the entered points appear on the screen if not using
the Commit command?
"PeterG" wrote in message
news:5623160@discussion.autodesk.com...
Hi Nathan.
the loop.
Regards
Peter
point to this code.
Module Coordinates
True)
Try
Begin:
ValueEntered = True
btr = DirectCast( _
BlockTableRecord)
'Exit Do
'Exit Do
Case "X"
Case "Y"
Case "All"
Case Else
End Select
tr.Commit()
Loop
GoTo Begin
tr.Abort()
tr.Abort()
Finally
docLock.Dispose()
End Try
End Sub
End Module
I figured it out. I had to move all of my Transaction commands inside the
while statement. Thanks for the help.
news:5628251@discussion.autodesk.com...
the Commit command?
Hi Nathan.
the loop.
Regards
Peter
point to this code.
Module Coordinates
True)
Try
Begin:
ValueEntered = True
btr = DirectCast( _
BlockTableRecord)
'Exit Do
'Exit Do
Case "X"
Case "Y"
Case "All"
Case Else
End Select
tr.Commit()
Loop
GoTo Begin
tr.Abort()
tr.Abort()
Finally
docLock.Dispose()
End Try
End Sub
End Module
