No Source Available, Cannot find or load PDB file
HJohn1
HJohn1
I am having problems debugging my AutoCAD 2014 project in VS2010.  I am getting the message "No Source Available" and the debugger hangs up.  I have search for this issue and it seems to be common problem, but I was not able to find a solution that works for me.  Has anybody experience this problem and can suggest how to go about it.  Windows 7 32bits, AutoCAD 2014, Visual Studio 2010 Express.
hgasty1001
Not sure, but usually you have to check "Enable Just My Code" in the debug options in VS (menu: TOOLS->Options...->Debugging). As for the pdb file, you can set the symbols for the debugger in the same options, and set the symbol server pointing to : http://symbols.autodesk.com .
Gaston Nunez
Maltezc
@hgasty1001, Out of curiosity, what is the significance of setting the symbol server?
