New inserted block doesn't seems to have snap point
Hi Guys,
I use the following code insert block
            Using myTrans As Transaction = db.TransactionManager.StartTransaction
                Dim myBT As BlockTable = db.BlockTableId.GetObject(OpenMode.ForRead)
                Dim myBTR As BlockTableRecord = myBT(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForWrite)
                'Insert the Block
                Dim myBlockDef As BlockTableRecord = _
                    myBT(Me.BlockName).GetObject(OpenMode.ForRead)
                myBlockRef = New DatabaseServices.BlockReference(InsertPoint, myBT(BlockName))
                myBlockRef.ScaleFactors = New Geometry.Scale3d(1, 1, 0)
                myBlockRef.Rotation = FixtureRotation
                myBTR.AppendEntity(myBlockRef)
                myTrans.AddNewlyCreatedDBObject(myBlockRef, True)
                myTrans.Commit()
            End Using
 After coe excuted new block has been insert. Then I found regardless I turn on/off onsap there is no sappoint on those newly added blocks.
It should looks like
my new inserted block
What did I do wrong? Any ideas ?
Thanks very much
arcticad
Just looking at your code the Z scale is at 0.
(defun botsbuildbots() (botsbuildbots))
Thanks for reply. I changed zscale to 1.0 , still no grip pointSmiley Sad
After more investigation. I found new inserted block display grip point, If I use "Line" command.
However once I run my own draw line function. the grip point turned off.
Even worse,after I run my own draw line code, back to AutoCAD "Line" command, those grip point never turn back
Here is my draw line code.
    Private Function DrawAlignLine(ByRef StartPoint As Point3d, ByRef EndPoint As Point3d, Optional ByRef strError As String = "") As Boolean
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Dim pPtRes As PromptPointResult
        Dim pPtOpts As PromptPointOptions = New PromptPointOptions("")
        Try
            '' Prompt for the start point
            pPtOpts.Message = vbLf & "Enter the start point of the line: "
            pPtRes = acDoc.Editor.GetPoint(pPtOpts)
            If pPtRes.Status <> PromptStatus.OK Then
                Return True
            End If
            StartPoint = pPtRes.Value
            pPtOpts.AllowNone = True
            '' Prompt for the end point
            pPtOpts.Message = vbLf & "Please enter the next point of the line: "
            pPtOpts.UseBasePoint = True
            pPtOpts.BasePoint = StartPoint
            Dim DrawComplete As Boolean = False
            Do
                    StartPoint = Nothing
                    Return True
                End If
                '--Start point different to end point
                If pPtRes.Value.IsEqualTo(StartPoint) = False Then
                    DrawComplete = True
                End If
            Loop Until DrawComplete = True
            EndPoint = pPtRes.Value
            Return True
        Catch sysex As SystemException
            strError = sysex.Message
            StorePlanLogError(sysex, sysex.Message, STR_MODULE_NAME & ".DrawAlignLine")
        Catch ex As Exception
            strError = ex.Message
            StorePlanLogError(ex, ex.Message, STR_MODULE_NAME & ".DrawAlignLine")
        End Try
    End Function
More investigation done, it is either a silly question or very strange one
Replication Step
1. Insert block(use the code I provided above)
2. type line command-->user can see new block grip point
3. Draw line use my code(code provided above)-->User cannot see grip point
4. Click Esc once, then type regen command, then type line command--> user can see grip point again
What on earth happened to my code
Please help
kerry_w_brown
By my reading of your code the DrawAlignLine does not draw a line, it just gets the start and end points.
Possibly related :
Why are you returning true if either of the point selections fail ?
I'd need to see a compilable Project to guess at the cause of your problem.
Regards
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Thanks for your reply.
The code is not draw line, it is finding 2 point. while doing that I can't see new block's grips point however I can see others.
That's the strange part.
Any idea?
