- Mute
- Permalink
- Report
Is there anything wrong with this code? It is called in a loop with changing filenames. AT the very end AutoCAD crashes.
public Substituter (string sOldString, string sNewString, string sSourceFullFileName, string sDestFullPath)
// The name won't change but the directory will
string sNameOnly = Path.GetFileName(sSourceFullFileName);
// Save as a new file
string sFullDestFileName = sDestFullPath + @"\" + sNameOnly;
using (Database db = new Database(false, true))
db.ReadDwgFile(sSourceFullFileName, FileOpenMode.OpenForReadAndWriteNoShare, false, "");
// closing the input makes sure the whole dwg is read from disk
// it also closes the file so you can SaveAs the same name
db.CloseInput(true);
// store the current working database, to reset
Database PreviousDb = HostApplicationServices.WorkingDatabase;
// set working database
HostApplicationServices.WorkingDatabase = db;
// { Do Some Work}
// Take this out and there is no crash...
db.SaveAs(sFullDestFileName, DwgVersion.Current);
// reset the working database
HostApplicationServices.WorkingDatabase = PreviousDb;
}It creates the files and then crashes at the end. If I don't call SaveAs it does not crash. What am I missing? The SaveAs apparently works though...!
