Netload settings
Netload settings
31750729
Observer Observer
Netload settings
31750729
Observer
Observer
Can anyone provide any guidance on how to revert the "Always load" setting from NETLOAD?
AVCPlugins
There are no options for manually loading plugins with the NetLoad command. Perhaps you meant the mode of automatic downloading of the plugin from the “bundle” folder. There the mode is configured in the PackageContents.xml file. You can specify LoadOnAutoCADStartup="True" in it.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
我印象中,
重新编译dll文件后,
对话框会再次出现。
这里有相关的文档
可以参考一下。
王磊
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
Alfred.NESWADBA
you may look to command _SECURITYOPTIONS as well as variable SECURELOAD.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
