Netload in AutoCAD 2005
Hi Friends,
I have made a .Net Dll in C#.Net and i am able to load that in AutoCAD 2006 and able to use that functions by passing commands.
But i am not able to load that Dll in AutoCAD 2005. I am getting some exception at command prompt. Can anybody help me out.
Regards
Basha
eLogic Solutions
If the .NET dll is created with Acad2006 ObjectARX .NET API, you cannot run
it on older version of Acad, just as all Object ARX program: onecreated on
older version of ACAD would run (most likely) on newer version Acad
installation, not the other way around.
wrote in message
news:5204067@discussion.autodesk.com...
Hi Friends,
Regards
Basha
eLogic Solutions
canyou use "netload" in the command line,
if you can use the command ,you will can load your "net.al";
i thinks it perhaps because of you using the version of the .net framework your Autocad doesn't permit.
you can see the acad.config.dll
