.NET Project with multiple dll. How to load them in a correct way?
gary.wuEQ8E4
gary.wuEQ8E4
Hey... I have a .NET solution that contains multiple projects since the application is a bit complex so I want to separate them. However, I am facing a problem is that how to load these assemblies in a right way.
So I have an main assembly, let's call it "Assembly A" and it refers to "Assembly B" and "Assembly C" and they are all store in the same directly. In the "Assembly A", it has an entry class implements `IExtensionApplication`. I open the AutoCAD and use command `NETLOAD`, select A, which loads correctly.
However, if I move "Assembly B" and "C" into a different folder and try to `NETLOAD` the assembly A. But assembly won't even execute. (I put a break point at `Initialize()` method but it never hit). I was wondering to `Load()` the reference assembly when it execute `Initialize()` method but since it never gets to that point, I won't be able to load reference assembly B and C.
So what's the best way to load a .net project that contains multiple dll? Why it doesn't work if I put reference assembly into different directory?
Ed__Jobe
When you build your solution, VS will put the compiled dll's into the \Bin\Release folder. Just copy all 3 dll's to the same deployment folder. When A loads, it will find the other 2 dll's and load them automatically. You don't manually load referenced files.
Ed
How to post your code.
Norman_Yuan
Firstly, you want ask yourself that why to place referenced DLL s in different folder?
If for some reasons you have to do it (for example, those shared DLLS may be shared by many other applications other than AutoCAD add-ins, then you may consider to digitally sign these assemblies and place them into GAC (Global Assembly Caches).
This document would help you to understand how .NET framework runtime locate required assemblies:
https://learn.microsoft.com/en-us/dotnet/framework/deployment/how-the-runtime-locates-assemblies
Norman Yuan
Drive CAD With Code
