Need to Batch Print to PDF, where do I begin?
Need some help getting started here.
Is the command "exportPDF" and various options available in .NET or VB.Interop?
Goal: To batch print (publish) drawings from our master database so we always have PDF's on hand in our shared drive.
I'm using Autocad 2011 with the included PDF feature.
michael_robertson
Here's a good place to start: http://through-the-interface.typepad.com/through_the_interface/2007/09/driving-a-multi.html
Cover multisheet plotting. Setting your pc3 file, etc.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
jeff
Here is a nice plug-in of the month
http://through-the-interface.typepad.com/through_the_interface/plotting/
You can also find your answers @ TheSwamp
Mike, a variation of this question:  I'm using the FDOT State Kit 2012.  All my Page Setups are from the FDOT Master .dwt, with FDOTPostScript.pc3 and the FDOT.stb Plot Style Table.  I'm not using Sheet Set Organizer, I just Publish to Plotter from Sheet Set Manager in C3D and convert all the postscripts to .pdf's.  When I do this, they plot perfectly and to scale.  However, if I try to Publish to PDF or DWFx, I get the origin offset shown in the attached .pdf.  Is there a way to fix this?
Pat
