Need help to set the TARGET variable zero in C#.
luckyboy82292
549 次查看
4 条回复
1 条消息(共 5 条)
luckyboy82292
Hey everyone!
As you can see from the title, I've tried changing the TARGET value, but it also changes the view in the model. How can I do this without affecting the view in the model tab?
Any help would be greatly appreciated. Thank you!
private void ResetTarget()
    using (Transaction tr = db.TransactionManager.StartTransaction())
        try
            ViewTableRecord vtr = ed.GetCurrentView();
            vtr.Target = new Point3d(0, 0, 0);
            ed.SetCurrentView(vtr);
            tr.Commit();
        catch (Exception ex)
            ed.WriteMessage($"\nError in ResetTarget function: {ex.Message}");
0 个赞
已接受的解答 (1)
550 次查看
4 条回复
回复 (4)
2 条消息(共 5 条)
ActivistInvestor
Your question doesn't make sense.
The Target property defines the center point of a view. If you apply a ViewTableRecord to the current view, it is going to modify the view to have the target specified in the ViewTableRecord.
0 个赞
3 条消息(共 5 条)
luckyboy82292
May we Zoom Extents in a new created side database before saving it? Or set an initial view?
0 个赞
4 条消息(共 5 条)
luckyboy82292
已接受的解答
I just found a solution when the TARGET is not equal to zero. The TARGET variable affects the plot window coordinates constantly. So, the solution is to create a translation matrix for it and always transform the plot window coordinates using this translation matrix. My code looks like this:
private Matrix3d GetTranslationMatrixFromTarget()
    try
        Point3d targetPoint = vtr.Target;
        if (!targetPoint.IsEqualTo(Point3d.Origin))
            Matrix3d translationMatrix = Matrix3d.Displacement(-targetPoint.GetAsVector());
            return translationMatrix;
        else
            return Matrix3d.Identity;
        ed.WriteMessage($"\nError in GetTranslationMatrixFromTarget function: {ex.Message}");
 And used like this:
private void ValidateAndPlot(Layout layOut, Point3d point0, Point3d point1, string path, string fileName, PlotProgressDialog pd)
    Matrix3d matrix3D = GetTranslationMatrixFromTarget();
    point0 = point0.TransformBy(matrix3D);
    point1 = point1.TransformBy(matrix3D);
    Point2d min = new Point2d(point0.X, point0.Y);
    Point2d max = new Point2d(point1.X, point1.Y);
    string style = layOut.CurrentStyleSheet;
    if (style == string.Empty)
        style = "acad.ctb";
    string plotDeviceName = "DWG To PDF.pc3";
    Extents2d pw = new Extents2d(min, max);
    try
        using (PlotInfo pi = new PlotInfo())
            pi.Layout = layOut.ObjectId;
            using (PlotSettings ps = new PlotSettings(layOut.ModelType))
                ps.CopyFrom(layOut);
                PlotSettingsValidator psv = PlotSettingsValidator.Current;
                psv.SetPlotWindowArea(ps, pw);
                psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Window);
                psv.SetPlotConfigurationName(ps, plotDeviceName, layOut.CanonicalMediaName);
                if (ps.CurrentStyleSheet == string.Empty)
                    psv.SetCurrentStyleSheet(ps, style);
                psv.SetPlotPaperUnits(ps, layOut.PlotPaperUnits);
                psv.SetUseStandardScale(ps, true);
                psv.SetStdScaleType(ps, StdScaleType.ScaleToFit);
                psv.SetPlotCentered(ps, true);
                psv.SetPlotRotation(ps, layOut.PlotRotation);
                pi.OverrideSettings = ps;
                using (PlotInfoValidator piv = new PlotInfoValidator())
                    piv.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
                    piv.Validate(pi);
                    if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting)
                        using (PlotEngine pe = PlotFactory.CreatePublishEngine())
                            pd.OnBeginPlot();
                            pe.BeginPlot(pd, null);
                            pe.BeginDocument(pi, null, null, 0, true, Path.Combine($"{path}\\{fileName}.pdf"));
                            pd.set_PlotMsgString(PlotMessageIndex.SheetProgressCaption, $"Plotting: {fileName}");
                            pd.OnBeginSheet();
                            PlotPageInfo ppi = new PlotPageInfo();
                            pe.BeginPage(ppi, pi, true, null);
                            pe.BeginGenerateGraphics(null);
                            pe.EndGenerateGraphics(null);
                            pd.SheetProgressPos = 100;
                            pd.OnEndSheet();
                            pe.EndPage(null);
                            pe.EndDocument(null);
                            pd.OnEndPlot();
                            pe.EndPlot(null);
                    else
                        throw new InvalidOperationException("Plot engine is in an invalid state.");
        throw new Exception($"{ex.Message}");
0 个赞
5 条消息(共 5 条)
ActivistInvestor
You can open the ViewportTableRecord having the name "*Active" and modify it.
0 个赞
