Name of Block from DBObject - Can anyone help
I am trying to obtain the name of a block from a Block Reference object
Private Function ReturnBlockName(ByVal oDBObject As DBObject) as string
If TypeOf oDBObject Is BlockReference Then
End If
End Function
In COM, you'd cast to an AcadBlockReference and query the Name property.
Look for something similar in the managed libraries.
KrishnaK
Archived Account
Chris,
You should open the blockReference's blockTableRecord to get its name.
For example:
_
Public Sub AsdkTest()
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim Ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim trans As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction
Try
Dim Opts As New PromptSelectionOptions()
'Build a filter list so that only block references are selected
Dim filList() As TypedValue = {New TypedValue(DxfCode.Start, "INSERT")}
Dim filter As SelectionFilter = New SelectionFilter(filList)
Dim res As PromptSelectionResult = Ed.GetSelection(Opts, filter)
'Do nothing if selection is unsuccessful
If Not res.Status = PromptStatus.OK Then Return
Dim SS As Autodesk.AutoCAD.EditorInput.SelectionSet = res.Value
Dim idArray As ObjectId() = SS.GetObjectIds()
Dim blockRefId As ObjectId
For Each blockRefId In idArray
Dim blRef As BlockReference
blRef = trans.GetObject(blockRefId, OpenMode.ForRead)
Dim btr As BlockTableRecord
btr = trans.GetObject(blRef.BlockTableRecord(), OpenMode.ForRead)
Ed.WriteMessage(vbCrLf + btr.Name + vbCrLf)
Next
Finally
trans.Dispose()
End Try
End Sub
Krishna Kalvai
DevTech
Autodesk Message was edited by: KrishnaK
wrote in message news:4855315@discussion.autodesk.com...
Chris,
For example:
_
Dim Ed As Editor =
Try
"INSERT")}
OpenMode.ForRead)
Next
Finally
trans.Dispose()
End Try
End Sub
Krishna Kalvai
DevTech
