Multiple Background Mtext
traiduong014969
traiduong014969
Hi everyone,
I have an issue that I need help with. Here are the details:
I created a command to make the background of multiple MText objects. However, after running this command, all the text merges into a single line. I would like to keep the original positions of the text. How can I achieve that?
 [CommandMethod("QM")]
        public void ApplyBackgroundMaskToMTexts()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptSelectionOptions pso = new PromptSelectionOptions();
            pso.MessageForAdding = "Select MText:";
            SelectionFilter filter = new SelectionFilter(new TypedValue[] { new TypedValue((int)DxfCode.Start, "MTEXT") });
            PromptSelectionResult psr = ed.GetSelection(pso, filter);
            if (psr.Status != PromptStatus.OK)
                ed.WriteMessage("\nNone Object selected.");
                return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                SelectionSet sset = psr.Value;
                foreach (SelectedObject selObj in sset)
                    if (selObj != null)
                        MText mtext = tr.GetObject(selObj.ObjectId, OpenMode.ForWrite) as MText;
                        if (mtext != null)
                            mtext.BackgroundFill = true;
                            mtext.BackgroundScaleFactor = 1;
                            mtext.BackgroundFillColor = Color.FromColorIndex(ColorMethod.ByAci, 1);
                            mtext.ColumnType = ColumnType.NoColumns;
                            mtext.Width = 0;
                            mtext.Height = 0;
                tr.Commit();
cuongtk2
Not set mtext.width, height
traiduong014969
Yes, if I don’t set the maximum width and height, some background areas and Mtext might be redundant
cuongtk2
Bạn hãy lưu giá trị width trước khi thay đổi mtext
traiduong014969
Yes, I repaired it like this, but it still combines into a single line
GiaBach
Add the UseBackgroundColor=false.
                        if (mtext != null)
                            //mtext.ColumnType = ColumnType.NoColumns;
                            //mtext.Width = 0;
                            //mtext.Height = 0;
                            mtext.UseBackgroundColor = false;
