Mtext Jig Issue or an alternative Mtext Jig getting Base point only
kite15
kite15
I have Mtext Jig whereas, having some error during long time run in while loop. Can you please, suggest the correct one or how can it make as bugs free ?
        public class MTextJig : EntityJig
            MText mtext;
            Point3d basePt, dragPt;
            public MTextJig(MText mtext)
                : base(mtext)
                this.mtext = mtext;
                basePt = mtext.Location;
            protected override SamplerStatus Sampler(JigPrompts prompts)
                var options = new JigPromptPointOptions("\nInsertion point: ");
                options.BasePoint = basePt;
                options.UseBasePoint = true;
                options.UserInputControls =
                    UserInputControls.Accept3dCoordinates |
                    UserInputControls.NullResponseAccepted |
                    UserInputControls.UseBasePointElevation;
                var result = prompts.AcquirePoint(options);
                if (result.Value.IsEqualTo(dragPt))
                    return SamplerStatus.NoChange;
                dragPt = result.Value;
                return SamplerStatus.OK;
            protected override bool Update()
                mtext.Location = dragPt;
                return true;
Thanks in Advance...
_gile
I do not see anythung wrong wrong in the code you posted, the issue is certainly due the way you call the Jig.
You should post the calling method.
Gilles Chanteau
GileCAD
GitHub
kite15
Here is the calling code and the error message......Smiley Sad
using (DocumentLock acLckDoc = doc.LockDocument())
using (var tr = db.TransactionManager.StartTransaction())
var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
ObjectId Tstyleid = db.Textstyle;
while (true)
using (var mtext = new MText())
mtext.Contents = OutTXTCompile(startVal);
mtext.Rotation = 0.0;
mtext.TextStyleId = Tstyleid;
curSpace.AppendEntity(mtext);
tr.AddNewlyCreatedDBObject(mtext, true);
MTextJig jig = new MTextJig(mtext);
var result = ed.Drag(jig);
if (result.Status != PromptStatus.OK)
mtext.Erase();
textBox_StrtVal.Text = (startVal - incrVal).ToString();
db.Textsize = txtSz;
break;
count++;
db.TransactionManager.QueueForGraphicsFlush();
startVal = startVal + incrVal;
tr.Commit();
Thanks....
