Hi All,
I am trying to swap one block for another and I have a multiline attribute, so I am trying to mimic the justification and alignment to be as per the original. I know that as a single line attribute, if the justification is Bottom left, I use position and if otherwise I use the alignment point. This works perfect!
Why does this not work with the Multiline Attribute but only when the justification is Left?
The IsMTextAttribute object gives me a new position that is Location, but this doesn't work either. I have tried the alignment point, the position even the attachment point, but for the life of me I cannot get the Right justified MtextAttributes to match that of the original block.
There is no subject matter on this that I can find anywhere. Does anyone have a hint that might get me where I need to be to move this attribute?
