Mtext Attribute Location / Alignmentpoint / Position
js75CAD
js75CAD
Hi All,
I am trying to swap one block for another and I have a multiline attribute, so I am trying to mimic the justification and alignment to be as per the original. I know that as a single line attribute, if the justification is Bottom left, I use position and if otherwise I use the alignment point. This works perfect!
Why does this not work with the Multiline Attribute but only when the justification is Left?
The IsMTextAttribute object gives me a new position that is Location, but this doesn't work either. I have tried the alignment point, the position even the attachment point, but for the life of me I cannot get the Right justified MtextAttributes to match that of the original block.
There is no subject matter on this that I can find anywhere. Does anyone have a hint that might get me where I need to be to move this attribute?
_gile
Have a look at MText properties in the documentation specifically Location and Attachment.
After having edited the MText, to update the attribute, you have to reset the modified MText as MTextAttribute:
attributeReference.MtextAttribute = mtext;
Gilles Chanteau
GileCAD
GitHub
js75CAD
_gile,
Thanks, but this doesn't work either. I am not sure why Autodesk go out of their way to make things so bloody difficult! How many points do you need? Location, attachmentpoint, alignmentPoint, Position... come on!
attNew.TextString = att.MTextAttribute.Contents
Select Case att.Justify.ToString
Case "MiddleRight"
attNew.MTextAttribute.Attachment = att.MTextAttribute.Attachment
attNew.AlignmentPoint = att.AlignmentPoint
Case Else
attNew.Justify = att.Justify
End Select
attNew.UpdateMTextAttribute()
This is what I have so far. If the MTextAttribute is Left justified, no problem. But the minute it becomes right justified, it keeps throwing the text. Now I have managed to make it just move slightly, but the grip point is moving and I am not sure what that point is? Below you can see what I am trying to achieve.
_gile
You have to first check if the attribute reference is a MTextAttribute and make things differently if it is or if it is not.
Something like this:
if(att.IsMTextAttribute)
    attNew.IsMTextAttribute = true;
    MText mtext = att.MTextAttribute;
    MText mtextNew = attNew.MTextAttribute;
    mtextNew.Location = mtext.Location;
    mtextNew.Attachment = mtext.Attachment;
    mtextNew.Contents = mtext.Contents;
    attNew.MTextAttribute = mtextNew;
else
    attNew.Position = att.Position;
    attNew.TextString = att.TextString;
    if (att.Justify == AttachmentPoint.BaseLeft)
        attNew.Justify = AttachmentPoint.BaseLeft;
    else
        attNew.Justify = att.Justify;
        attNew.AlignmentPoint = att.AlignmentPoint;
Gilles Chanteau
GileCAD
GitHub
js75CAD
Thank you _gile!
I had already checked if it was (sorry i should have included that part of the code), but I misunderstood what you meant by the Mtext. I now know what I did wrong.
Admittedly, I still am struggling to understand the difference between all the points, but now I have this, I will start testing different scenarios to see how they change. I just wish they has some documentation on this.
Much appreciated and whereever you are in the world, have an awesome weekend!
