Modify all dynamic blocks in a DWG file with C#
Hello!
I am new to the AutoCAD API. I hope you can help me.
My goal is to modify the distance of all the dynamic blocks of an AutoCAD plan.
On a first try, I am modifying all the dynamic blocks using the following code. This approach works fine and I can see how the dynamic blocks change in AutoCAD.
[CommandMethod("test1")]
static public void Test1()
var dimensions = new Dictionary<string, double> { { "LMB", 750 }, { "H", 400 }, { "S", 44 }, { "Z", 6 }, { "X", 30 }, { "Y", 120 } };
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Transaction tr = db.TransactionManager.StartTransaction();
Editor editor = doc.Editor;
using (tr)
var result = editor.SelectAll();
SelectionSet ss = result.Value;
ObjectId[] ids = ss.GetObjectIds();
var blockReferenceList = new List();
foreach (var id in ids)
var br = tr.GetObject(id, OpenMode.ForRead) as BlockReference;
if (br != null && br.IsDynamicBlock)
blockReferenceList.Add(br);
foreach (var br in blockReferenceList)
DynamicBlockReferencePropertyCollection pc = br.DynamicBlockReferencePropertyCollection;
foreach (DynamicBlockReferenceProperty prop in pc)
if (prop.UnitsType == DynamicBlockReferencePropertyUnitsType.Distance)
var dimension = dimensions.SingleOrDefault(x => x.Key == prop.PropertyName);
if (dimension.Key != null)
prop.Value = dimension.Value;
tr.Commit();
In a second attempt, what I need is to modify all the dynamic blocks by loading a DWG file into memory, modifying it and then saving the changes to disk. I am using the following code but it is not working. Can you help me with this, please?
[CommandMethod("test2")]
static public void Test2()
const string file = @"C:\CAD\temp.dwg";
using (var db = new Database(false, true))
db.ReadDwgFile(file, FileShare.Read, false, "");
db.CloseInput(true);
using (var tr = db.TransactionManager.StartTransaction())
var wdb = HostApplicationServices.WorkingDatabase;
HostApplicationServices.WorkingDatabase = db;
BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
foreach (var id in bt)
BlockReference br = tr.GetObject(id, OpenMode.ForRead) as BlockReference;
tr.Commit();
HostApplicationServices.WorkingDatabase = wdb;
db.SaveAs(file, DwgVersion.Current);
Note: Something to note is that the line highlighted in red always returns null.
Thanks!
