Modify a selected attribute value in a block
I am trying to modify an attribute value in a block which I can select it on screen. The question is: when selecting the block, if the entity I pick is an attribute part of the block, can I get the attribute's tag? What I am trying to do is to update a revision block, changing one particular value but the attribute's tag it is not the same it can be different from drawing to drawing.
Thanks for your suggestions.
E.G.
norman.yuan
You can use Editor.GetNestedEntity() to allow user to directly pick an AttributeReference inside a BlockReference. Then update the Attributereference
Norman Yuan
Drive CAD With Code
Yuan,
About the getnestedentity()
My situation:
I'm standing in paperspace. This has one vp.
Can i use the above method to select an entity in the vp wich i've not opend. So i need to select an entity(drawn in modelspace) while standing in paperspace. I need the to get xrecord information so i can automate my annotation.
Hope you understand my problem.
Otherwise please let me know.
Kind regard,
Irvin
Thanks Norman,
it solved my problem.
E.G.
kerry_w_brown
How ?
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Here is the sample code(might need some adjusment): whatever text I have in the clipboard I'll paste it into attribute:
    <CommandMethod("44")> _
    Public Sub UpdateAttributeValue()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        Dim rs As PromptNestedEntityResult = ed.GetNestedEntity(vbLf & "Select attribute: ")
        Dim sTemp As String = String.Empty
        sTemp = My.Computer.Clipboard.GetText
        If sTemp = String.Empty Then
            MsgBox("There is no text in clipboard. Please copy some..")
            Return
        End If
        If rs.Status = PromptStatus.OK Then
            Dim oid As ObjectId = rs.ObjectId
            Using tr As Transaction = doc.TransactionManager.StartTransaction()
                Dim ent As Entity = DirectCast(tr.GetObject(oid, OpenMode.ForRead), Entity)
                If TypeOf ent Is AttributeReference Then
                    Dim attref As AttributeReference = DirectCast(ent, AttributeReference)
                    attref.UpgradeOpen()
                    attref.TextString = sTemp
                End If
                tr.Commit()
            End Using
        End If
    End Sub
 E.G.
