Modeless dialog/Insertion point
Message 1 of 12
I have modeless dialog. On dialog I have button on which user clicks, when he wants to pick insertion point. Problem is when I exit dialog the command line is still in command GetPoint (doesn't show usual Command:). How can I solve this problem? My code at the moment is:
           // this.Visible = false;
            AppServ.Document adoc = AppServ.Application.DocumentManager.MdiActiveDocument;
           AppServ.DocumentLock dl = adoc.LockDocument();
            Editor ed = adoc.Editor;
            using (ed.StartUserInteraction(this))
                PromptPointOptions ppo = new PromptPointOptions("Pick Point:");
                PromptPointResult respt = ed.GetPoint(ppo);
                if (respt.Status == PromptStatus.OK)
                       //Do something
                dwg.Dispose();
            dl.Dispose();
           // this.Visible = !this.Visible;
Replies (11)
Message 2 of 12
Hi carl,
Kan you tell me how you invoke your command to display the modeless form?
Are you using a commandmethod or are you invoking a method directly from your class???
When your invoking a method thats the problem. All commands need to be invoked trough a commandmethod attribbute.
Otherwise you will get this strange behavior of the command line.
kind regards,
irvin
Message 3 of 12
Somehow like this:
    public void dialog()
       Dlg dlg = new Dlg();
       dlg.Show(new WindowWrapper(AcadApp.MainWindow.Handle));
    [CommandMethod("Test")]
    static public void Test()
         dialog();
Message 4 of 12
can you post an image of the command line?
Message 5 of 12
It looks like this when I close dialog (this.Close()).
Message 6 of 12
Alfred.NESWADBA
if I understand you right then invoking acedPostCommandPrompt will help, look >>>this<<<
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 7 of 12
this.close is called by a button?
Message 8 of 12
Yes, by button on the modeless form.
Message 9 of 12
Looking at the code you use when startting user interaction please look at this.
//Editor ed = AcadAppServ.Application.DocumentManager.MdiActiveDocument.Editor;
            using (AcadAppServ.DocumentLock docLock = AcadAppServ.Application.DocumentManager.MdiActiveDocument.LockDocument())
                using( EditorUserInteraction edUsrInt = ed.StartUserInteraction(this))
                    PromptPointOptions prPtOpts = new PromptPointOptions("\nPlease select a point to place the ellipse:");
                    PromptPointResult prPtRes = ed.GetPoint(prPtOpts);
                    Utilities.AddEllipse(prPtRes.Value);
                    prPtOpts.Message = "\nPlease select a point to place the circle:";
                    Utilities.AddCircle(prPtRes.Value);
                    edUsrInt.End();
I think the problem is caused nod ending the userinteraction edUsrInt.End()
Message 10 of 12
Irvin and Alfred, thanks for replies. At the moment I tried Alfreds suggestion and it works. Imported ObjectARX/LISP command "acedPostCommandPrompt()" does the trick. I will also try Irvins last suggestion if it works. Thanks again.
Message 11 of 12
BTW, you have equivalent function in .NET
Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
Message 12 of 12
Even better. I will try it. Thanks!
