Model / Render Type GsClassFactory
Anyone know the equivalent of getting a AcGsModel with a render type of kDirect similar to that of the old BlockView example in ObjectArx. The function used the AcGsClassFactory::createModel(...) but I cannot seem to find an equivalent to this in .Net.
I am currently using an in-memory Database to display graphical objects. Now I want to add "Ghost" objects to the View where they are not added to the Database and displayed over-top of the database resident objects. How can I accomplish this in .Net.
Any tips would be appreciated.
Mike
norman.yuan
Maybe TransientGraphics?
Norman Yuan
Drive CAD With Code
DiningPhilosopher
Have you looked at the BlockView.NET sample?
I have, and based my view on that. The difference is that the BlockView .Net example does not include the orbit object which the original block view has.
- Mike
fenton_webb
It seems like the transient api is definitely the way for you... Check out Keans blog http://through-the-interface.typepad.com/through_the_interface/2011/03/using-transient-graphics-to-s...
In terms of creating an AutoCAD model using .NET, here's some code that might be useful to someone. I wrote it pretty quickly so please excuse any bugs, logic errors.
    // command to generate DWG and Block thumbnail bitmaps
    // by Fenton Webb, DevTech, 24/1/2013
    [CommandMethod("GENERATETHUMBS")]
    public void GenerateThumbnailBitmaps()
      Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
      // get the output path for the bitmaps
      PromptStringOptions opts = new PromptStringOptions("\nEnter output path : ");
      opts.AllowSpaces = true;
      PromptResult res = ed.GetString(opts);
      // if ok
      if (res.Status == PromptStatus.OK)
        try
          // make sure the folder exists
          DirectoryInfo outputPathInfo = new DirectoryInfo(res.StringResult);
          if (outputPathInfo.Exists)
            Point2d screenSize = (Point2d)Application.GetSystemVariable("SCREENSIZE");
            // set up the image sizes
            int width = (int)screenSize.X;
            int height = (int)screenSize.Y;
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            // get the dwg file name
            FileInfo dwgPath = new FileInfo(doc.Name);
            // get the document graphics system manager
            Manager gsm = doc.GraphicsManager;
            // construct the default filename prefix and path
            string defaultPath = outputPathInfo.FullName + "\\" + dwgPath.Name.Replace(".dwg", " ");
            // first generate the MS screen shot
            View acadView = gsm.GetGsView(2, true);
            Rectangle rect = new Rectangle(0, 0, width, height);
            using (Bitmap msBmp = acadView.GetSnapshot(rect))
              msBmp.Save(defaultPath + " MS.bmp");
            // now set the block sizes to something standard
            width = 800;
            height = 600;
            // now generate the layout images
            // first remember the current layout
            string currentLayout = LayoutManager.Current.CurrentLayout;
            // now lets loop the layouts, open the layout dict
            using (DBDictionary layoutDict = db.LayoutDictionaryId.Open(OpenMode.ForRead) as DBDictionary)
              // now iterate the layouts and get the names
              foreach (DBDictionaryEntry layoutEntry in layoutDict)
                string layoutName = layoutEntry.Key;
                LayoutManager.Current.CurrentLayout = layoutName;
                using (Bitmap layoutBmp = doc.CapturePreviewImage((uint)width, (uint)height))
                  layoutBmp.Save(defaultPath + " " + layoutName + ".bmp");
                /*View layoutView = gsm.GetGsView(1, true);
                using (Bitmap layoutBmp = layoutView.GetSnapshot(rect))
                  layoutBmp.Save(defaultPath + " " + layoutName + ".bmp");*/
            // restore the original layout
            LayoutManager.Current.CurrentLayout = currentLayout;
            // now create an off screen device
            using (Device offDevice = gsm.CreateAutoCADOffScreenDevice())
              // now size the device
              offDevice.OnSize(new System.Drawing.Size(width, height));
              // now create the view
              using (View view = new View())
                // add the new view object to the device
                offDevice.Add(view);
                // update it
                offDevice.Update();
                // ok now create the model
                using (Model model = gsm.CreateAutoCADModel())
                  using (BlockTable bt = db.BlockTableId.Open(OpenMode.ForRead) as BlockTable)
                    // now iterate through our block tables
                    foreach (ObjectId id in bt)
                      // open the btr for read
                      using (BlockTableRecord btr = id.Open(OpenMode.ForRead) as BlockTableRecord)
                        // get the name of the block for the BMP file name
                        string btrName = btr.Name;
                        // add the btr to the view
                        view.Add(btr, model);
                        try
                          // get the extents of the btr
                          Extents3d extents = new Extents3d();
                          extents.AddBlockExtents(btr);
                          // now zoom extents of the view
                          view.ZoomExtents(extents.MinPoint, extents.MaxPoint);
                          // finally, construct the filepath
                          string imagePath = defaultPath + btrName + " Block.bmp";
                          // clean up the path
                          imagePath = imagePath.Replace("*", "");
                          // snap the image
                          using (Bitmap blockBmp = view.GetSnapshot(rect))
                            blockBmp.Save(imagePath);
                        catch
                        // reset the view for the next iteration
                        view.EraseAll();
                offDevice.EraseAll();
          else
            ed.WriteMessage("\nThe Path is invalid: " + res.StringResult);
        catch
          ed.WriteMessage("\nThe Path cannot be written to: " + res.StringResult);
Fenton Webb
AutoCAD Engineering
