mirrored text problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
Linear or Rotated dimension which needs to be mirrorred. I am using the following code for creating the dimension and its mirrored dimension. The problem is that the dimension text getting mirrored (reversed) in the mirrored dimension. I have tried using Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("MIRRTEXT", 0); but it still shows mirrored text. Can somebody please help. Here's my code:
The problem is not only dimension text but also Text & Mtext.
I am using Autocad map 3D-2011 version.
For creating dimension:
RotatedDimension acRotDim1 = new RotatedDimension();
acRotDim1.XLine1Point = new Point3d(0, 0, 0);
acRotDim1.XLine2Point = new Point3d(X.X , X.Y , 0);
acRotDim1.Rotation = 0.0;
acRotDim1.DimLinePoint = new Point3d(0, -200, 0);
acRotDim1.DimensionStyle = acCurDb.Dimstyle;
// Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acRotDim1);
acTrans.AddNewlyCreatedDBObject(acRotDim1, true);
For mirroring:
private void Mirror(Transaction t, BlockTableRecord btr,Entity e)
// Create a copy of the original entity
Entity eCopy = e.Clone() as Entity;
// Define the mirror line
Point3d acPtFrom = new Point3d(A69.X, A69.Y, 0);
Point3d acPtTo = new Point3d(A71.X, A71.Y, 0);
Line3d acLine3d = new Line3d(acPtFrom, acPtTo);
// Mirror the entity
eCopy.TransformBy(Matrix3d.Mirroring(acLine3d));
// Add the new object to the block table record and the transaction
btr.AppendEntity(eCopy);
t.AddNewlyCreatedDBObject(eCopy, true);
Regards
Sudarsan
