MDA: LoaderLock
MDA: LoaderLock
MDA: LoaderLock
Painfully new to .NET, working with VS 2005, Autocad 2006. Previously
working through some simple stuff in VS 2003 and the projects were working
fine. Migrated the projects to 2005 and tried to run them in Debug and I get
this error repeatedly:
Message: Attempting managed execution inside OS Loader lock. Do not attempt
to run managed code inside a DllMain or image initialization function since
doing so can cause the application to hang.
Things run once I get through the messages, but I don't understand what I've
apparently missed. Thanks for any help.
Ben Rand
CAD Manager
CEntry Constructors & Engineers
brand@centry.net
See http://msdn2.microsoft.com/en-us/library/ms172219.aspx for your specific
problem and
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dv_vstechart/html/vcconmixeddllloadingproblem.asp
for background information.
Dan
"Ben Rand" wrote in message
news:5041866@discussion.autodesk.com...
Ben Rand
CAD Manager
brand@centry.net
Thanks for the info. Unfortunately I don't know what to do with it. Sorry,
just extremely new to .NET. Nothing changed from when the project was in
VS2003 and worked without this message.
"J. Daniel Smith" wrote in message
news:5042081@discussion.autodesk.com...
problem and
Dan
Ben Rand
CAD Manager
brand@centry.net
Thanks again for your help, Dan. The answer was in this first document you
sent me to, but it took hearing that from ADN DevHelp again to pound it
through my head--or help me understand that I was staring at the solution.
The fix was apparently to disable MDAs. This is a specific solution for
Autocad 2006/VS 2005 (because Acad 2006 was built with version 1.1 of the
.NET framework).
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework]
"MDA"="1"Once I added this key to the registry, the error messages were
gone.
Ben
problem and
Dan
Ben Rand
CAD Manager
brand@centry.net
for me setting the key
"MDA"="0"
seemed to work?
Juha
news:5045217@discussion.autodesk.com...
.NET framework).
gone.
Ben
problem and
Dan
Ben Rand
CAD Manager
brand@centry.net
"Ben Rand" wrote ...
.NET framework).
Well, I read the document and I'm lost...
I'm running VS 2005 builds for AutoCAD 2006 using Framework 2.0 and my code
is written in C#.
It sounds like they're saying the AutoDesk developers need to correct the
problem and re-compile their code in Framework 2.0. Are we simply disabling
the warning without resolving the problem? If I manage to diagnose the
problem, is there anything I can do about it, some code I can modify?
Fred Chateau
fchateauAtComcastDotNet
AutoCAD will use the most recent version of the
framework installed, unless you set acad.exe.config
to use a specific version.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"Fred Chateau" wrote in message news:5051943@discussion.autodesk.com...
.NET framework).
is written in C#.
Fred Chateau
