Material from color, without texture
E3DE
E3DE
Is it possible to create a material only with color, without texture?
I use the follow code to create a marerial from texture, how modify it to use a simple color?
Thank you
// Create the texture map image
ImageFileTexture tex = new ImageFileTexture();
tex.SourceFileName = sTextureMapPath;
// We need a cylindrical mapping with no tiling
Mapper mapper = new Mapper(PlatformDb.GraphicsInterface.Projection.Box,
                                            Tiling.Clamp,
                                            Tiling.Clamp,
                                            AutoTransform.TransformObject,
                                            Matrix3d.Identity);
MaterialMap map = new MaterialMap(Source.File,
                                        tex,
                                        1.0,
                                        mapper);
// Set the opacity and refraction maps
MaterialDiffuseComponent mdc = new MaterialDiffuseComponent(new
  MaterialColor(), map);
MaterialRefractionComponent mrc = new MaterialRefractionComponent(2.0, map);
// Create a new material
Material mat = new Material();
mat.Name = sMaterialName;
mat.Diffuse = mdc;
mat.Refraction = mrc;
mat.Mode = Mode.Realistic;
mat.Reflectivity = 1.0;
mat.IlluminationModel = IlluminationModel.BlinnShader;
mat.Opacity = new MaterialOpacityComponent(opacityPercentage, new
  MaterialMap());
// Add it to the library
matLib.UpgradeOpen();
materialId = matLib.SetAt(sMaterialName, mat);
_gile
What about using a GenericTexture instead of an ImageFileTexture.
                                        new GenericTexture(),
                                        1.0,
                                        mapper);
Gilles Chanteau
GileCAD
GitHub
E3DE
Thank you,
where can I set the color, for example red?
For example in a solid, I want to set to some faces a texture (from image file) material and other with a simple color (red, blue, etc).
_gile
var mat = new Material();
var color = new EntityColor(ColorMethod.ByAci, 1); // or: new EntityColor(255, 0, 0);
mat.Ambient = new MaterialColor(Method.Override, 1.0, color);
Gilles Chanteau
GileCAD
GitHub
E3DE
Thank you,
I modify my method, the materil is created but without color inside, something is probably missing.
public static ObjectId AddMaterialFromColor(String sMaterialName, EntityColor entityColor, double opacityPercentage = 1)
            ObjectId materialId = ObjectId.Null;
            Document doc = Application.DocumentManager.MdiActiveDocument;
            using (Transaction tr = doc.TransactionManager.StartTransaction())
                // Get the material library
                DBDictionary matLib = tr.GetObject(doc.Database.MaterialDictionaryId, OpenMode.ForRead) as DBDictionary;
                // If this material does not exist
                if (matLib.Contains(sMaterialName) == false)
                    mat.Ambient = new MaterialColor(Method.Override, 1.0, entityColor);
                    mat.Opacity = new MaterialOpacityComponent(opacityPercentage, new MaterialMap());
                    tr.AddNewlyCreatedDBObject(mat, true);
                    tr.Commit();
                else
                    materialId = matLib.GetAt(sMaterialName);
            return materialId;
Thank you
_gile
It looks like you also need to define the Diffuse and Specular properies with the color.
var matColor = new MaterialColor(Method.Override, 1.0, color);
mat.Ambient = matColor;
mat.Diffuse = new MaterialDiffuseComponent(matColor, map);
mat.Specular = new MaterialSpecularComponent(matColor, map, 1.0);
Gilles Chanteau
GileCAD
GitHub
E3DE
Thank you @_gile , now it works fine.
Here the complete method:
                                            Tiling.Clamp,
                                            Tiling.Clamp,
                                            Matrix3d.Identity);
                                        1.0,
                                        mapper);
                    var matColor = new MaterialColor(Method.Override, 1.0, entityColor);
                    tr.Commit();
                else
            return materialId;
