Make XRef path relative
WPerciful
Message 1 of 8
WPerciful
I can't seem to figure out how to make the xref file path relative.
    Public Sub ProjectCloseOut(Directory_DrawingName As String, ByVal FileType As String)
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim db As Database = New Database(False, True)
        Dim XrGraph As XrefGraph = db.GetHostDwgXrefGraph(False)
        XrGraph = db.GetHostDwgXrefGraph(True)
        Dim root As GraphNode = XrGraph.RootNode
        Dim r As New List(Of String)
        Using db
            Try 'FileOpenMode.OpenForReadAndAllShare
                db.ReadDwgFile(Directory_DrawingName, FileOpenMode.OpenForReadAndAllShare, False, Nothing)
            Catch __unusedException1__ As System.Exception
                ed.WriteMessage(vbLf & "Unable To read drawing file.")
            End Try
            Using tran = db.TransactionManager.StartTransaction
                For o As Integer = 0 To root.NumOut - 1
                    Dim child As XrefGraphNode = TryCast(root.Out(o), XrefGraphNode)
                    Select Case child.XrefStatus
                        Case XrefStatus.Resolved
                            '   Make all of the xrefs relitive paths
                            Dim XrefFullFileName = child.Database.Filename
                            Dim XrefFilePath = IO.Path.GetDirectoryName(AecFullFileName)
                            Dim XrefFileName = IO.Path.GetFileNameWithoutExtension(AecFullFileName)
                            dtProjectCloseOutFiles.Rows.Add(XrefFullFileName, XrefFilePath, XrefFileName, FileType)
                        Case XrefStatus.FileNotFound Or XrefStatus.Unloaded Or XrefStatus.Unreferenced
                            '   xrefs for all model files in 3D Model folder and detach them
                            Dim acXrefId As ObjectId = db.AttachXref(XrefFullFileName, XrefFileName)
                            db.DetachXref(acXrefId)
                    End Select
                Next
            End Using
        End Using
    End Sub
Same code in C#
public void ProjectCloseOut(string Directory_DrawingName, string FileType)
    Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
    Database db = new Database(false, true);
    XrefGraph XrGraph = db.GetHostDwgXrefGraph(false);
    XrGraph = db.GetHostDwgXrefGraph(true);
    GraphNode root = XrGraph.RootNode;
    List<string> r = new List<string>();
    using (db)
        try // FileOpenMode.OpenForReadAndAllShare
            db.ReadDwgFile(Directory_DrawingName, FileOpenMode.OpenForReadAndAllShare, false, null/* TODO Change to default(_) if this is not a reference type */);
        catch (Exception __unusedException1__)
            ed.WriteMessage(Constants.vbLf + "Unable To read drawing file.");
        using (var tran = db.TransactionManager.StartTransaction)
            for (int o = 0; o <= root.NumOut - 1; o++)
                XrefGraphNode child = root.Out(o) as XrefGraphNode;
                switch (child.XrefStatus)
                    case object _ when XrefStatus.Resolved:
                            // Make all of the xrefs relitive paths
                            var XrefFullFileName = child.Database.Filename;
                            var XrefFilePath = System.IO.Path.GetDirectoryName(AecFullFileName);
                            var XrefFileName = System.IO.Path.GetFileNameWithoutExtension(AecFullFileName);
                            dtProjectCloseOutFiles.Rows.Add(XrefFullFileName, XrefFilePath, XrefFileName, FileType);
                            break;
                    case object _ when XrefStatus.FileNotFound | XrefStatus.Unloaded | XrefStatus.Unreferenced:
                            // xrefs for all model files in 3D Model folder and detach them
                            ObjectId acXrefId = db.AttachXref(XrefFullFileName, XrefFileName);
                            db.DetachXref(acXrefId);
                            break;
Wayne Perciful
Founder | Perciful Consulting LLC
Perciful Consulting
Replies (7)
Message 2 of 8
Ed__Jobe
You can remove the paths using the Xref Manager that ships with AutoCAD. Just load the dwgs to be changed and change the path to ".\"
Ed
How to post your code.
Message 3 of 8
WPerciful
I've got over 1,000 files at a time that I need to perform this on.  Which is why I'm attempting to automate the task.
Wayne Perciful
Perciful Consulting
Message 4 of 8
jabowabo
I think @Ed__Jobe is referring to AdRefMan.exe which will batch rename xrefs:
C:\Program Files\Autodesk\AutoCAD <version>\AdRefMan.exe
If you still want to code it, this may help. There's some custom method calls but should be easy to figure out.
public static void MakeXrefPathsRelative()
	ObjectIdCollection objIdColl = new ObjectIdCollection();
	string nl = Environment.NewLine;
	// set flags for openFileDialog and select dwgs
	string defaultFolder = @"S:\Drafting";
	OfdFlags ofdFlags = OfdFlags.DefaultIsFolder | OfdFlags.AllowMultiple;
	List<string> dwgFilePaths = FileTools.GetDwgFileNames(defaultFolder, ofdFlags);
	if (dwgFilePaths == null || dwgFilePaths.Count == 0)
		return;
	foreach (string dwgFilePath in dwgFilePaths)
		// save old database
		Database prevDb = HostApplicationServices.WorkingDatabase;
		using (Database dwgDb = new Database(false, true))
			dwgDb.ReadDwgFile(dwgFilePath, FileShare.Read, true, "");
			dwgDb.CloseInput(true);
			// set the dwg as active
			HostApplicationServices.WorkingDatabase = dwgDb;
			using (Transaction tr = dwgDb.TransactionManager.StartTransaction())
				BlockTable bt = tr.GetObject(dwgDb.BlockTableId, OpenMode.ForRead) as BlockTable;
				foreach (ObjectId btrId in bt)
					BlockTableRecord btr = tr.GetObject(btrId, OpenMode.ForRead) as BlockTableRecord;
					if (btr.IsFromExternalReference)
						btr.UpgradeOpen();
						String oldXrefPath = btr.PathName;
						Uri path1 = new Uri(dwgFilePath);
						Uri path2 = new Uri(oldXrefPath);
						Uri diff = path1.MakeRelativeUri(path2);
						string relPath = diff.OriginalString;
						string newXrefPath = relPath.Replace(@"%20", " ");
						btr.PathName = newXrefPath;
						objIdColl.Add(btrId);
						Debug.AppendLine("Old Path : {oldXrefPath} New Path : {newXrefPath}");
				tr.Commit();
			}// end transaction
			// reset to prev db it back ASAP
			HostApplicationServices.WorkingDatabase = prevDb;
			dwgDb.SaveAs(dwgFilePath, dwgDb.GetThisDwgVersion());
		}// end using dwgDb
	}// end foreach sourceFile
	if (Debug.Enabled)
		Debug.Dump("ModifyXrefPathLogFile", false, true);
Message 5 of 8
Ed__Jobe
@WPerciful Yes, you can access it from the Start Menu. I've loaded hundreds of files at a time. It's very capable of doing it in batch mode. Do Ctrl+A to select all the files and you're good to go. Even if you bread up the 1000 into a few groups of 200-300, it'll  be quicker than writing your own app. You could have been done by now. 🙂
Ed
Message 6 of 8
kerry_w_brown
@jabowabo
nice solution.
.NET core 2.0  onwards has a Path.GetRelativePath(String, String) Method
https://learn.microsoft.com/en-us/dotnet/api/system.io.path.getrelativepath?view=netcore-2.0
. . but oficially we can't use that yet.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 7 of 8
WPerciful
Still working on figuring out what you shared.  Haven't gotten anywhere with it as yet.  Can you add some comments to your code?
Wayne Perciful
Perciful Consulting
Message 8 of 8
jabowabo
Here's a cleaned up version. This one acts on the current document.
	var doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
	var db = doc.Db;
	var thisDwgPath = db.OriginalFileName;
	using (DocumentLock docLock = doc.LockDocument())
		using (Transaction tr = db.TransactionManager.StartTransaction())
			BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
			// iterate all bt objects
				// check if object is xref
					// open for write
					btr.UpgradeOpen();
					// orig path
					// make new relative path
					Uri path1 = new Uri(thisDwgPath);
					// assign new path
			tr.Commit();
		}// end transaction
	}// end docLock
