Make Table Header a Data Row
SRSDS
Advisor Advisor
SRSDS
I'm inserting a standard TableStyle that has a header row and data rows beneath.
The header row is a single merged cell that I want changed to a data row.
So I need to either
  •  Unmerge row(0) cells
  • Change row(0)'s style to "Data"
  • Hide or suppress row(0)
I can't figure out how to achieve any of the three, and can't find any thread posts successful in achieving it.
_gile
Try:
table.Rows[0].Style = "_DATA";
Gilles Chanteau
GileCAD
GitHub
SRSDS
That's one of the ones I tried, but got an "eNotApplicable" error as this person  did.
fieldguy
_gile
You have to set the TableStyle property before setting the Rows[0].Style.
Here's an example:
[CommandMethod("TEST")]
public static void Test()
    var doc = Application.DocumentManager.MdiActiveDocument;
    var db = doc.Database;
    int numRows = 4;
    double rowHeight = 9.0;
    int numColumns = 3;
    double columnWidth = 40.0;
    using (var tr = db.TransactionManager.StartTransaction())
        var tableStyles = (DBDictionary)tr.GetObject(db.TableStyleDictionaryId, OpenMode.ForWrite);
        var tableStyle = tableStyles.GetAt("Standard");
        var table = new Table();
        table.TableStyle = tableStyle;
        table.Columns[0].Width = columnWidth;
        table.InsertColumns(1, columnWidth, numColumns - 1);
        table.InsertRows(1, rowHeight, numRows - 1);
        for (int i = 0; i < numRows; i++)
            table.Rows[i].Style = "_DATA";
        table.Position = Point3d.Origin;
        var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
        curSpace.AppendEntity(table);
        tr.AddNewlyCreatedDBObject(table, true);
        tr.Commit();
Gilles Chanteau
GileCAD
GitHub
SRSDS
Thank you!
I've spent quite a long time trying to work that out.
