make existing layer as active layer
almutaz_86
almutaz_86
Good morning,
there is some thing wrong with this code, I cant figure it
when layer exist , it dosen't make it as active layer
private void Layercreate(string Layer_Name)
using (var dbs = HostApplicationServices.WorkingDatabase)
using (var Trans = dbs.TransactionManager.StartTransaction())
try
LayerTable Layer_Table = (LayerTable)Trans.GetObject(dbs.LayerTableId, OpenMode.ForRead);
LayerTableRecord layer_chk;
foreach (ObjectId layer_chk_id in Layer_Table)
layer_chk = Trans.GetObject(layer_chk_id, OpenMode.ForRead) as LayerTableRecord;
if (Layer_Table.Has(Layer_Name))// check if layer exist
string Active_Layer = Convert.ToString(dbs.Clayer);
if (Active_Layer != Layer_Name)//check if requsted layer is the current layer
dbs.Clayer = Layer_Table[Layer_Name];//make existing layer as current
break;
else
Trans.Commit();
break;
else
{	//create layer if it is not exist
ObjectId Layer_Object_ID = dbs.LayerTableId;
Layer_Table = Trans.GetObject(Layer_Object_ID, OpenMode.ForWrite) as LayerTable;
LayerTableRecord Layer_Tablerec = new LayerTableRecord
Name = Layer_Name
Layer_Table.Add(Layer_Tablerec);
Trans.AddNewlyCreatedDBObject(Layer_Tablerec, true);
Application.SetSystemVariable("clayer", Layer_Name);//make it current, is there better way to do this ??
Trans.Commit();
break;
catch (Autodesk.AutoCAD.Runtime.Exception _Exeption)
Editor editor = Application.DocumentManager.MdiActiveDocument.Editor;
editor.WriteMessage("\n" + Convert.ToString(_Exeption));
_gile
Try to make the things as simple as possible. You shoud not get the working database in a using statement, you do not really need to check which is the current layer (anyway, Convert.ToString(dbs.Clayer) always return false because dbs.Clayer is an ObjectId) and overall you do not need to iterate through the layer table and do all the stuff for each layer (even committing the transaction).
private void CreateLayer(string layerName)
    var db = HostApplicationServices.WorkingDatabase;
    using (var tr = db.TransactionManager.StartTransaction())
        var layerTable = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
        // if the layer table does not already contain the layer, create it
        if (!layerTable.Has(layerName))
            tr.GetObject(db.LayerTableId, OpenMode.ForWrite);
            var layer = new LayerTableRecord { Name = layerName };
            layerTable.Add(layer);
            tr.AddNewlyCreatedDBObject(layer, true);
        // make layerName current
        db.Clayer = layerTable[layerName];
        tr.Commit();
Gilles Chanteau
GileCAD
GitHub
almutaz_86
I appreciate you very much @_gile
and thank you
I'm really struggling to keep codes simple, but I dont have enough experience in .net
if you may please to recommend a toturial for AutoCAD .net api  ?
Thanks again
jaboone
How would you apply all the other things to this function so that it modifies the color, lock, transparency, noplot, on/off, description and linestyle?  Did I miss anything?
Learning as I go
_gile
Simply set the properties  of the LayerTableRecord instance.
Gilles Chanteau
GileCAD
GitHub
jaboone
Thanks.  I see you are completely right to add to the table.
I modified this line
Dim layer = New LayerTableRecord With {.Name = LayerName, .LineWeight = LineWeight.ByLayer, .IsLocked = False, .Description = LayerDescription, .IsPlottable = IsItPlottable, .IsFrozen = False}
Thanks for the help
Learning as I go
jaboone
One problem I see with this layer table is that I can't set the layer created to a current layer with adding a new command line to do it.  Can you talk to your API group to add a .SetCurrent = True to make it a all for one, then I could use a create layer each time I want to set a layer?  Or maybe there is a better method?
Learning as I go
