Looping Thru all objects (Blocks) in drawing
I want to loop through all blockreferences and entities in Model Space and Layout space...
Can I do that in one loop?
Can I do something like for each object in Drawing database?
What's the object set I'm looking for here?
Here's the beginning of my current code.
       'Start(Transaction)
        Using myTrans As Transaction = DatabaseIn.TransactionManager.StartTransaction
            Dim myBT As BlockTable = DatabaseIn.BlockTableId.GetObject(OpenMode.ForRead)
            Dim myModelSpace As BlockTableRecord = myBT(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForRead)
            'For Each Object in ModelSpace
            For Each myObjID As ObjectId In myModelSpace
                Dim myEnt As Entity = myObjID.GetObject(OpenMode.ForRead)
                If TypeOf myEnt Is Autodesk.AutoCAD.DatabaseServices.Line Then
jeff
One thing you could do is loop through the blocktable then get the entites in blocktablerecords that are layouts(IsLayout = true).
or get modelspace then get the blocktablerecords through the LayoutDictionary.
You can also find your answers @ TheSwamp
