Loop Thru Sheets Via Display Order
ChrisPicklesimer
ChrisPicklesimer
With the following code I can randomly loop through sheets in a dst file data base.  Is thare a way to loop through the sheets via their diplay order in the sheet set manager?  Ultimately I am looking to increment a custom property that is based on display order.
Thanks.
Chris
Private Sub LoopThruSheets(ByVal sheetSetDatabase As IAcSmDatabase)
        ' Get the objects in the sheet set
        Dim enumerator As IAcSmEnumPersist
        enumerator = sheetSetDatabase.GetEnumerator()
        ' Get the first object in the Enumerator
        Dim item As IAcSmPersist
        item = enumerator.Next()
        ' Step through all the objects in the sheet set
        Do While Not item Is Nothing
            Dim sheet As IAcSmSheet = Nothing
            ' Check to see if the object is a sheet
            If item.GetTypeName() = "AcSmSheet" Then
                sheet = item
                MsgBox(sheet.GetName.ToString)
            End If
            ' Get the next Sheet
        Loop
    End Sub
The enumerator should iterate through the sheets in their natural order, which
is what the SSM displays them in.
I used the SSM to drag a sheet to a different position within its subset
(A110 - Fire Rating Plans in the screenshot), and that's the order it
appears in when my code iterates the sheets in the subset.
ChrisPicklesimer
I have tried it multiple times but the iteration order does not seem to change for me even after I adjusted the odrer via the SSM.  Just out of curiousity, did you use the code I posted when you ran your test?  I tested using ACA 2008.  Would that make a difference?
Thanks.
Chris
Are you closing and reopening the SheetSet before trying? If not,
that may be it.
I'm not using your code. The code that I use to populate the treeview
shown in the screenshot uses GetDirectlyOwnedObjects() rather the
iterators, which might also explain the difference.
I'm using vanilla AutoCAD so I can't say for sure if ACA's variant of the
SSM is doing something differently.
jshimkus
How did you adjust the sheet order using the SSM?
ChrisPicklesimer
I click on the sheet and drag into position.
jshimkus
OK, I thought you had found a way to do it via code.
