Loading a Lisp file with VB.net
GeeHaa
GeeHaa
Is there a way to Load a lisp file from VB.net? All  I want to do is load it so its available at the command Prompt.
Thanks in Advance
BlackBox_
Have you tried SendStringToExecute() Method?
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
GeeHaa
I only will do that as a last resort.
I tried
Autodesk.AutoCAD.Internal.Utils.RegisterLispCommand(LispCommandName, LispFilename)
But I get an eKeyNotFound error. I can't find any documentation about this method so I'm not sure what it does.
G
Virupaksha_aithal
Autodesk Support
Autodesk Support
It is better to avoid using any internal API, in this case RegisterLispCommand, when an alternative method (SendStringToExecute) is available. Internal methods will not have any documentation
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
ebikoba
How do you use the SendStringToExecute? I need an example please for loading a lisp routine.
Virupaksha_aithal
Autodesk Support
Autodesk Support
Please refer https://forums.autodesk.com/t5/net/can-you-do-an-appload-from-a-c-program/td-p/5810305
