Load dll-files in Acad2013
stefan.hofer
Message 1 of 11
stefan.hofer
Someone already tried to load VB dll's in Acad2013?
They dont work for me - no message and no error, nothing happens.
in 2012 they worked well.
Replies (10)
Message 2 of 11
Alfred.NESWADBA
do you mean VB6 dll's oder VB.NET dll's
Have you set new references (according to AutoCAD 2013/19.0) before you compiled the DLL's?
A little bit little, your info 😉
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 11
stefan.hofer
ahhhh
you'r right i have to rebuild my scripts with the r19 references...
i hope this works - i get errors in my code with the new references.
thanks
Message 4 of 11
Alfred.NESWADBA
Yes, there are some modifications necessary to your code as there are some moves of functions/properties to different DLLs/different namespaces. But as long as we don't see what error you have we can't do anything for you 😉
- alfred -
Alfred NESWADBA
Message 5 of 11
stefan.hofer
ok, one error left...
    Public ReadOnly Property ThisDrawing As AcadDocument
        Get
            Return   Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.AcadDocument
        End Get
    End Property
 msg:
AcadDocument is not a member of Autodesk.AutoCAD.ApplicationServices.Document
Message 6 of 11
Alfred.NESWADBA
one global change you have to do is to add a new DLL to the references:
AcCoreMgd.dll
To your statement getting asscess to the COM-based AcadDocument you have to use this way:
Dim tAcadDoc as ApplicationServices.Document
Dim tAcadDocCOM as Interop.AcadDocument
tAcadDoc = ApplicationServices.Application.DocumentManager.MdiActiveDocument
tAcadDocCOM = CType(ApplicationServices.DocumentExtension.GetAcadDocument(tAcadDoc), Interop.AcadDocument)
HTH, - alfred -
Alfred NESWADBA
Message 7 of 11
stefan.hofer
Ty for your help, but i have a other problem now LOL Smiley Sad
EDIT:
OK, i updated my project to NETframework 4.0... seems to work now. Thank you very much!
Message 8 of 11
stefan.hofer
To get "ThisDrawing" i use
Return DocumentExtension.GetAcadDocument(Application.DocumentManager.MdiActiveDocument)
 now.
if someone have the same problem...
Message 9 of 11
Thanks Alfred,
DocumentExtension worked for me.
I have to make a code of my ex-colleague usable for AutoCAD 2015, so i don't have much experience with the code.
The problem is that  he declared tAcadDoc as editor.
If i use your code i wont get that error anymore (tAcadDoc --> doc1) (tAcadDocCOM --> ed) but it gives me extra errors after it.
Dim ed as ApplicationServices.Document
Dim doc1 as Interop.AcadDocument
ed = ApplicationServices.Application.DocumentManager.MdiActiveDocument
doc1 = CType(ApplicationServices.DocumentExtension.GetAcadDocument(ed), Interop.AcadDocument)
Old code:
  Dim doc1 As Autodesk.AutoCAD.Interop.AcadDocument = Application.DocumentManager.MdiActiveDocument.AcadDocument
            Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Because ed is now declared as ApplicationServices.Document, i can't use for example ed.WriteMessage because it's not declared as editor anymore:
ed.WriteMessage(vbCrLf & "Initializing - Loading User Preferences - ST-CadCommands." & vbCrLf)
I tried to declare ed as editor but then it says that it can't convert ApplicationServices.Application.DocumentManager.MdiActiveDocument to EditorIput.Editor
I have added accoremgd, acdbmgd, AcDx, Acmgd, AutoCAD, Interop, Interop.Common and AXDBLib to the references
Can you help me further?
Arjan
Message 10 of 11
stefan.hofer
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim ed As Editor = doc.Editor
 try this...
Message 11 of 11
Thank you very much:)
That totally worked for me!
