Load arx
Load arx
Message 1 of 8
Load arx
in old ActiveX, there is the possibilty to load an arx with
Application.LoadArx
and list the load arx with
Application.ListArx
Is there an aquivalent in dotnet?
Thanks for help
Tim
Replies (7)
Message 2 of 8
Check out the ExtensionLoader Class. It has both Load and IsLoaded
methods.
"Tim Fields" wrote in message
news:[email protected]...
Application.LoadArx
Application.ListArx
Thanks for help
Tim
Message 3 of 8
Thanks for your answer, but I tried ExtensionLoader.IsLoaded already. I
got an exception:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.Reflection.TargetInvocationException: Exception has been thrown by
the target of an invocation. ---> System.BadImageFormatException: Could
not load file or assembly 'D:\AutoCAD 2007\test.arx' or one of its
dependencies. The module was expected to contain an assembly manifest.
File name: 'D:\AutoCAD 2007\test.arx'
at System.Reflection.AssemblyName.nGetFileInformation(String s)
at System.Reflection.AssemblyName.GetAssemblyName(String assemblyFile)
at Autodesk.AutoCAD.Runtime.ExtensionLoader.IsLoaded(String fileName)
at xyz.abc.test() in D:\test\clsMain.cs:line 32
=== Pre-bind state information ===
LOG: User = -\-
LOG: Where-ref bind. Location = D:\AutoCAD 2007\test.arx
LOG: Appbase = file:///D:/AutoCAD 2007/
LOG: Initial PrivatePath = NULL
Calling assembly : (Unknown).
The arx I try to load is a non-managed arx (without clr support) created
in VS 2005 for AutoCAD 2007 and works properly.
Tim
Message 4 of 8
I thought you we're loading a managed extension. I don't know if there is a
class to load
an ARX. If nothing else maybe you could just use the ARX command?
got an exception:
LOG: User = -\-
Tim
Message 5 of 8
Hi Paul
The ExtensionLoader class is for managed extensions.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
"Paul Richardson" wrote in message news:[email protected]...
methods.
Application.LoadArx
Application.ListArx
Thanks for help
Tim
Message 6 of 8
using Autodesk.AutoCAD.Runtime;
SystemObjects.DynamicLinker.LoadModule(...);
"Tim Fields" wrote in message news:[email protected]...
got an exception:
LOG: User = -\-
Tim
Message 7 of 8
YTM! As usual...Thanks.
"Tony Tanzillo" wrote in message
Hi Paul
methods.
Application.LoadArx
Application.ListArx
Thanks for help
Tim
Message 8 of 8
Thanks for all your answers.
Solved it with using the 'AutoCAD COM APIs from .NET' and
'ApplicationServices.Application.AcadApplication', which has LoadARX und
ListARX.
Tim
