Message 1 of 9
I've modified several jig codes that I've found but I still really don't know what I'm doing.
I'd like a jig that creates a leader starting from the nearest point to a line to the last mouse position.
Needless to say it's not working.
Below is what I have fumbled together. Hope someone can help.
<CommandMethod("AA", CommandFlags.UsePickSet Or CommandFlags.Redraw Or CommandFlags.Modal Or CommandFlags.NoBlockEditor Or CommandFlags.Session)>
Sub LabelJig()
Using docLock As DocumentLock = Application.DocumentManager.MdiActiveDocument.LockDocument()
Using trans As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction : trcnt = trcnt + 1
Dim RJC As nsLabel_Range.RangeLabelJig2 = New nsLabel_Range.RangeLabelJig2
RJC.AddLabel(trans) 'LabelType supposed to be "Range"
trans.Commit() : trcnt = trcnt - 1 : If trcnt > 0 Then MsgBox(Reflection.MethodBase.GetCurrentMethod.Name() + " - TRCNT>0")
End Using
End Using
End SubImports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Geometry
Namespace nsLabel_Range
Public Class RangeLabelJig2
Public Shared mt_RotationUCS As Double, mt_Height As Integer, vector As Vector2d
Public Shared ml_angleUCS As Double, ml_angleWCS As Double, ml_dogleglength As Double
Public Shared myLine As Line
Public Sub AddLabel(ByRef trans As Transaction)
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
Dim btr As BlockTableRecord = trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite, False)
myLine = New Line(New Point3d(0, 0, 0), New Point3d(1000, 0, 0))
Dim jig As New MLeaderJig(" ", LabelTxtStyleID, trans)
Dim dragres As PromptResult = ed.Drag(jig)
If dragres.Status = PromptStatus.OK Then
Dim bt As BlockTable = DirectCast(trans.GetObject(db.BlockTableId, OpenMode.ForRead, False), BlockTable)
Try
Dim ent As Entity = jig.GetEntity
btr.AppendEntity(ent)
trans.AddNewlyCreatedDBObject(ent, True)
Catch ex As Exception
MsgBox(Reflection.MethodBase.GetCurrentMethod.Name() + " Exception: " + ex.Message)
End Try
End Sub
Private Class MLeaderJig
Inherits EntityJig
'Private m_pts As Point3dCollection
Private lastMousePosition As Point3d
Private m_contents As String
Private m_leaderIndex As Integer
Private m_leaderLineIndex As Integer
Public Sub New(ByVal contents As String, ByVal txtId As ObjectId, ByVal Trans As Transaction)
MyBase.New(New MLeader())
m_contents = contents
Dim ml As MLeader = TryCast(Entity, MLeader)
ml.SetDatabaseDefaults()
m_leaderIndex = ml.AddLeader()
m_leaderLineIndex = 0
End Sub
Protected Overrides Function Sampler(ByVal prompts As JigPrompts) As SamplerStatus
Dim jigOpt As New JigPromptPointOptions()
jigOpt.UserInputControls = UserInputControls.Accept3dCoordinates Or UserInputControls.AnyBlankTerminatesInput Or UserInputControls.GovernedByOrthoMode Or UserInputControls.GovernedByUCSDetect Or UserInputControls.UseBasePointElevation Or UserInputControls.InitialBlankTerminatesInput Or UserInputControls.NullResponseAccepted
jigOpt.Message = vbLf & "Label End Point: "
Dim res As PromptPointResult = prompts.AcquirePoint(jigOpt)
If res.Value = lastMousePosition Then
Return SamplerStatus.NoChange
ElseIf res.Status = PromptStatus.OK Then
lastMousePosition = res.Value
Return SamplerStatus.OK
Return SamplerStatus.Cancel
End Function
Protected Overrides Function Update() As Boolean
ed.WriteMessage(vbLf + "lastMousePosition=" & lastMousePosition.X & "," & lastMousePosition.Y)
Try
Dim AngleBetweenUCSandWCS As Double = GetAngleBetweenUCSandWCS()
m_leaderLineIndex = ml.AddLeaderLine(m_leaderIndex)
Dim m_labelOrigin As Point3d = myLine.GetClosestPointTo(lastMousePosition, False)
ml.AddFirstVertex(m_leaderLineIndex, m_labelOrigin)
ml.AddLastVertex(m_leaderLineIndex, New Point3d(0, 0, 0))
ml.SetLastVertex(m_leaderLineIndex, lastMousePosition)
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
doc.Editor.WriteMessage(vbLf & "MLeader Jig Exception: " & ex.Message)
Return False
End Try
Return True
End Function
Public Function GetEntity() As Entity
Return Entity
End Function
End Class
End Class
End Namespace
