How do I make a 2D rectangle
Please excuse me I am new and an idiot...I cannot find the beginners section. I cannot find anything....
I am trying to watch tutorials to tech myself. But I am have trouble with the very basics....
I found this instruction:
How do you make a rectangular selection in AutoCAD?
Select objects by clicking them or by using a window or crossing method.
  1. To specify a rectangular selection area, click and release the mouse button, move the cursor, and click again.
This is not working for me…..
I am using the mouse in my right hand. I left click release and drag the mouse making the rectangle.
Then I click again….but it disappears. If I right click I get a lot of options, but still the rectangle disappears.
I am sure it is second nature to an expert like you, but I am stuck. There is no point in going any further unless I can at least make a rectangle.
Can you help and idiot with this very basic. Question.
Many apologies for put this request somewhere that I know it is not supposed to be....but I am lost and confused.
tbrammer
This is a developer forum, not a user forum. But anyway - try this:
Open the options dialog (by right click menu or command _OPTIONS).
Click to the tab "Selection" (in German it is "Auswahl") and change the selection method ("Fensterauswahlmethode") to "both" or "click & click".
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
dgorsman
Just to be clear: are you trying to select something?  Or are you trying to draw something?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Sir/Madam
Thank you.
I am learning and just trying to draw rectangle, etc from scratch.
Thank you
Regards
Dan
Sir
My apologies. I was unaware.
I cannot find the OPTIONS button/tab..?
Just by the way, how do I change the programme wide preference to metric.
Thank you
Dan
tbrammer
I thought you were asking how to make a rectangular SELECTION.
Now I understand that you misunderstood the meaning of "How do you make a rectangular selection in AutoCAD?".
So to draw a rectangle you can either type the command "_RECTANG" (without quotes) or click on the command button (sorry, german screenshot):
To bring up the options dialog you can either type "_OPTIONS" and hit <RETURN> or right click anywhere and select the last item of the context menu.
The units are stored in the drawing. Usually you use a template drawing like acad.dwt or acadiso.dwt that defines the drawing units.
