Layout Manager - switching Layouts
How do you get access to the layout manager?
I found this posted under ObjectARX
AcApLayoutManager *pLayM = NULL;
pLayM = (AcApLayoutManager *)
acdbHostApplicationServices()->layoutManager();
AcDbLayout *pLayout =
pLayM->findLayoutNamed(pLayM->findActiveLayout(TRUE),TRUE);
This lead me to believe that I can create a reference to the object using this line
Dim oLayoutManager As LayoutManager = HostApplicationServices.WorkingDatabase.?
I would like to switch layouts using .Net.
The easiest way to find out things (which is obviously
NOT the er 'documentation'), is to use Reflector and its
search function.
LayoutManager manager = LayoutManager.Current;
Also keep in mnd that many classes follow this pattern
(where there's no public c'tor and instead, you must call
a static member to get an instance).
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:4871047@discussion.autodesk.com...
Thanks Tony,
I am still kinda green when it comes to .net and ObjectARX.
This line worked in VB.Net
Dim oLayoutManager As LayoutManager = LayoutManager.Current
Now, for the other half of my question.
How do I switch layouts? I guess that I wrongly assumed that something called a "LayoutManager" would allow me to switch the active layout.
How about the .CurrentLayout property?
According to the object browser, that property is read-only
Never Mind,
Current : Read Only
CurrentLayout : Not Read Only
