Layerstates, Layerstatemasks in vb
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
My goal is to batch plots using VB in Visual Studio 2008, Autocad Map 3D 2010, Win 7 Pro 64. It all works but now I want to apply layerstates.
I am using the example in the dev. guide here: http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html
My questions: (any answers or advice is appreciated)
1. If you use Option Strict, how do you convert from integer to "layerstatesmasks.color"? VS shows the error "Option Strict On disallows implicit conversions from 'Integer' to 'Autodesk.AutoCAD.DatabaseServices.LayerStateMasks'." I can't figure out the conversion. Are the values documented somewhere? "clientmask" is not in the object browser or the dev. guide.
2. If you aren't sure what is masked, do you turn on all of the options on (on, color, linetype, lineweight, etc.)? Is there a sum of values that means "layerstatemasks.all"?
3. LAS files are DXF format. Do I have to read the LAS to detemine what the user wants?
4. The second argument to .restorelayerstate is the viewport id. The examples use objectid.null. I could have several layouts to plot, and maybe several viewports. Is the process a) Make the layout current, b) activate each viewport, c) set model space current, and d) restore the layerstate?
